Inset tool sensitivity is dependent on object scale
Operating system: Windows 10
Graphics card: GTX1080Ti
Broken: 2.8 latest master
Worked: probably never
Sensitivity of many of the modeling tools is dependent on their scale. That is not helpful... for anything... ever... There's not a single case where such behavior would be desired.
1, Create a new blender scene.
2, Select default cube, go to edit mode and perform inset
3, Notice the sensitivity is fine
4, Exit edit mode, and scale the cube up 10x (10 scale)
5, Enter edit mode again and perform another inset
6, Notice the inset sensitivity is totally out of control
7, Exit the edit mode, and apply the scale to the cube
8, Enter the edit mode again, perform another inset, and notice the sensitivity is fine again
Result: Sensitivity is of modeling tools is dependent on the scale of the mesh
Expected: Sensitivity of modeling tools is NOT dependent on the scale of the mesh
This behavior requires users to compulsively apply transforms every single time they perform any scaling manipulation of the mesh they work with so that the modeling tools remain usable. This in turn makes the entire workflow quite uncomfortable.
Sebastian Parborg (zeddb) triaged this task as Confirmed, Medium priority.
We already have a report of this for bevel, which shares the same code.
Beyond that this bug report is too broad, and more user feedback than a bug report.
1, The bug report this has been closed as a duplicate of concerns completely different issue. This one is related to the scale, the other one is not.
2, The example with inset tool is not broad, it's very specific.
So the report is basically thrown away, because the fix of the other issue, which this is supposedly duplicate of, will most likely not solve this issue.
Brecht Van Lommel (brecht) renamed this task from Modeling tool sensitivity is dependent on object scale to Inset tool sensitivity is dependent on object scale.Feb 28 2019, 3:52 PM
Brecht Van Lommel (brecht) reopened this task as Open.
Brecht Van Lommel (brecht) lowered the priority of this task from Confirmed, Medium to Confirmed, Low.
Ok, I confused it with the other report.
