Smoke Crash with Cycles animation #62121
Closed
opened 2019-03-02 14:31:45 +01:00 by Jaro · 18 comments
Operating system: Win10 (Build 17763)
Graphics card: GTX1070
Broken: blender2.8, 2019-02-05, as found on the splash screen
Set "Cycles" as render engine and shading type set to "Rendered". Play an animation after that blender crashes.
1.Open the attached file Smoke.blend
2. Set the shading to "Rendered"
3. play animation
**System Information** Operating system: Win10 (Build 17763) Graphics card: GTX1070 **Blender Version** Broken: blender2.8, 2019-02-05, as found on the splash screen **Short description of error** Set "Cycles" as render engine and shading type set to "Rendered". Play an animation after that blender crashes. **Exact steps for others to reproduce the error** 1.Open the attached file [Smoke.blend](https://archive.blender.org/developer/F6745128/Smoke.blend) 2. Set the shading to "Rendered" 3. play animation
Author
Added subscriber: @JayZe3D
#63851 was marked as duplicate of this issue
#65504 was marked as duplicate of this issue
#65168 was marked as duplicate of this issue
Added subscriber: @ZedDB
Please retry with the most recent blender beta.
Author
Hi,
the same with the latest Beta version from 03. March.
regards
Jaro
Hi, the same with the latest Beta version from 03. March. regards Jaro
Added subscriber: @LazyDodo
@LazyDodo can you reproduce this?
Author
Hi again,
I could reproduce it with another computer. It´s a laptop HP Spectra x360, I7, 16Gb, 1TB SSD, Intel UHD Graphics 620 and latest version Blender 2019-03-04.
best regards
Jaro
Hi again, I could reproduce it with another computer. It´s a laptop HP Spectra x360, I7, 16Gb, 1TB SSD, Intel UHD Graphics 620 and latest version Blender 2019-03-04. best regards Jaro
Brecht Van Lommel self-assigned this 2019-03-14 13:55:20 +01:00
Member
Member
That is certainly a threading issue. I can have these two call stacks at the same time:
ccl::ImageManager::file_load_image<(OpenImageIO_v1_8::TypeDesc::BASETYPE)11, float, float>(ccl::ImageManager * const this, ccl::ImageManager::Image * img, ccl::ImageDataType type, int texture_limit, ccl::device_vector<float> & tex_img) (/home/jacques/blender-git/blender/intern/cycles/render/image.cpp:582)
ccl::ImageManager::device_load_image(ccl::ImageManager * const this, ccl::Device * device, ccl::Scene * scene, ccl::ImageDataType type, int slot, ccl::Progress * progress) (/home/jacques/blender-git/blender/intern/cycles/render/image.cpp:829)
std::__invoke_impl<void, void (ccl::ImageManager::*&)(ccl::Device*, ccl::Scene*, ccl::ImageDataType, int, ccl::Progress*), ccl::ImageManager*&, ccl::Device*&, ccl::Scene*&, ccl::ImageDataType&, unsigned long&, ccl::Progress*&>(void (ccl::ImageManager::*&)(ccl::ImageManager * const, ccl::Device *, ccl::Scene *, ccl::ImageDataType, int, ccl::Progress *) __f, ccl::ImageManager *& __t,  __args#0,  __args#1,  __args#2,  __args#3,  __args#4) (/usr/include/c++/7/bits/invoke.h:73)
std::__invoke<void (ccl::ImageManager::*&)(ccl::Device*, ccl::Scene*, ccl::ImageDataType, int, ccl::Progress*), ccl::ImageManager*&, ccl::Device*&, ccl::Scene*&, ccl::ImageDataType&, unsigned long&, ccl::Progress*&>(void (ccl::ImageManager::*&)(ccl::ImageManager * const, ccl::Device *, ccl::Scene *, ccl::ImageDataType, int, ccl::Progress *) __fn,  __args#0,  __args#1,  __args#2,  __args#3,  __args#4,  __args#5) (/usr/include/c++/7/bits/invoke.h:95)
std::_Bind<void (ccl::ImageManager::*(ccl::ImageManager*, ccl::Device*, ccl::Scene*, ccl::ImageDataType, unsigned long, ccl::Progress*))(ccl::Device*, ccl::Scene*, ccl::ImageDataType, int, ccl::Progress*)>::__call<void, int&&, 0ul, 1ul, 2ul, 3ul, 4ul, 5ul>(std::tuple<int&&>&&, std::_Index_tuple<0ul, 1ul, 2ul, 3ul, 4ul, 5ul>)(std::_Bind<void (ccl::ImageManager::*(ccl::ImageManager*, ccl::Device*, ccl::Scene*, ccl::ImageDataType, long unsigned int, ccl::Progress*))(ccl::Device*, ccl::Scene*, ccl::ImageDataType, int, ccl::Progress*)> * const this, std::tuple<int&&> && __args) (/usr/include/c++/7/functional:467)
std::_Bind<void (ccl::ImageManager::*(ccl::ImageManager*, ccl::Device*, ccl::Scene*, ccl::ImageDataType, unsigned long, ccl::Progress*))(ccl::Device*, ccl::Scene*, ccl::ImageDataType, int, ccl::Progress*)>::operator()<int, void>(int&&)(std::_Bind<void (ccl::ImageManager::*(ccl::ImageManager*, ccl::Device*, ccl::Scene*, ccl::ImageDataType, long unsigned int, ccl::Progress*))(ccl::Device*, ccl::Scene*, ccl::ImageDataType, int, ccl::Progress*)> * const this,  __args#0) (/usr/include/c++/7/functional:551)
std::_Function_handler<void (int), std::_Bind<void (ccl::ImageManager::*(ccl::ImageManager*, ccl::Device*, ccl::Scene*, ccl::ImageDataType, unsigned long, ccl::Progress*))(ccl::Device*, ccl::Scene*, ccl::ImageDataType, int, ccl::Progress*)> >::_M_invoke(std::_Any_data const&, int&&)(const std::_Any_data & __functor,  __args#0) (/usr/include/c++/7/bits/std_function.h:316)
std::function<void (int)>::operator()(int) const(const std::function<void(int)> * const this,  __args#0) (/usr/include/c++/7/bits/std_function.h:706)
ccl::TaskPool::wait_work(ccl::TaskPool * const this, ccl::TaskPool::Summary * stats) (/home/jacques/blender-git/blender/intern/cycles/util/util_task.cpp:98)
ccl::ImageManager::device_load_builtin(ccl::ImageManager * const this, ccl::Device * device, ccl::Scene * scene, ccl::Progress & progress) (/home/jacques/blender-git/blender/intern/cycles/render/image.cpp:1074)
ccl::BlenderSession::builtin_images_load(ccl::BlenderSession * const this) (/home/jacques/blender-git/blender/intern/cycles/blender/blender_session.cpp:1451)
ccl::BlenderSession::synchronize(ccl::BlenderSession * const this, BL::Depsgraph & b_depsgraph_) (/home/jacques/blender-git/blender/intern/cycles/blender/blender_session.cpp:897)
ccl::sync_func(PyObject * args) (/home/jacques/blender-git/blender/intern/cycles/blender/blender_python.cpp:399)
libpython3.7m.so.1.0!_PyMethodDef_RawFastCallKeywords (Unknown Source:0)
libpython3.7m.so.1.0!_PyCFunction_FastCallKeywords (Unknown Source:0)
libpython3.7m.so.1.0!_PyEval_EvalFrameDefault (Unknown Source:0)
pydevd_frame_evaluator.cpython-37m-x86_64-linux-gnu.so!__pyx_f_18_pydevd_frame_eval_22pydevd_frame_evaluator_get_bytecode_while_frame_eval(PyFrameObject * __pyx_v_frame_obj, int __pyx_v_exc) (/io/ptvsd/src/ptvsd/_vendored/pydevd/_pydevd_frame_eval/pydevd_frame_evaluator.c:7198)
libpython3.7m.so.1.0![Unknown/Just-In-Time compiled code] (Unknown Source:0)
and
ccl::TextureInterpolator<float>::interp_3d_linear(float z, float y, float x, const ccl::TextureInfo & info) (/home/jacques/blender-git/blender/intern/cycles/kernel/kernels/cpu/kernel_cpu_image.h:338)
ccl::TextureInterpolator<float>::interp_3d(ccl::InterpolationType interp, float z, float y, float x, const ccl::TextureInfo & info) (/home/jacques/blender-git/blender/intern/cycles/kernel/kernels/cpu/kernel_cpu_image.h:461)
ccl::kernel_tex_image_interp_3d(ccl::KernelGlobals * kg, int id, float x, float y, float z, ccl::InterpolationType interp) (/home/jacques/blender-git/blender/intern/cycles/kernel/kernels/cpu/kernel_cpu_image.h:510)
ccl::volume_attribute_float(ccl::KernelGlobals * kg, const ccl::ShaderData * sd, const ccl::AttributeDescriptor desc) (/home/jacques/blender-git/blender/intern/cycles/kernel/geom/geom_volume.h:57)
ccl::primitive_volume_attribute_float(const ccl::AttributeDescriptor desc, const ccl::ShaderData * sd, ccl::KernelGlobals * kg) (/home/jacques/blender-git/blender/intern/cycles/kernel/geom/geom_primitive.h:86)
ccl::svm_node_principled_volume(ccl::KernelGlobals * kg, ccl::ShaderData * sd, float * stack, ccl::uint4 node, ccl::ShaderType shader_type, int path_flag, int * offset) (/home/jacques/blender-git/blender/intern/cycles/kernel/svm/svm_closure.h:1062)
ccl::svm_eval_nodes(ccl::KernelGlobals * kg, ccl::ShaderData * sd, ccl::PathState * state, ccl::ShaderType type, int path_flag) (/home/jacques/blender-git/blender/intern/cycles/kernel/svm/svm.h:357)
ccl::shader_eval_volume(int path_flag, ccl::VolumeStack * stack, ccl::PathState * state, ccl::ShaderData * sd, ccl::KernelGlobals * kg) (/home/jacques/blender-git/blender/intern/cycles/kernel/kernel_shader.h:1318)
ccl::volume_shader_sample(ccl::VolumeShaderCoefficients * coeff, ccl::float3 P, ccl::PathState * state, ccl::ShaderData * sd, ccl::KernelGlobals * kg) (/home/jacques/blender-git/blender/intern/cycles/kernel/kernel_volume.h:67)
ccl::kernel_volume_decoupled_record(ccl::KernelGlobals * kg, ccl::PathState * state, ccl::Ray * ray, ccl::ShaderData * sd, ccl::VolumeSegment * segment, bool heterogeneous) (/home/jacques/blender-git/blender/intern/cycles/kernel/kernel_volume.h:806)
ccl::kernel_path_volume(ccl::PathRadiance * L, ccl::ShaderData * emission_sd, bool hit, ccl::Intersection * isect, ccl::float3 * throughput, ccl::Ray * ray, ccl::PathState * state, ccl::ShaderData * sd, ccl::KernelGlobals * kg) (/home/jacques/blender-git/blender/intern/cycles/kernel/kernel_path.h:184)
ccl::kernel_path_integrate(ccl::ShaderData * emission_sd, float * buffer, ccl::PathRadiance * L, ccl::Ray * ray, ccl::float3 throughput, ccl::PathState * state, ccl::KernelGlobals * kg) (/home/jacques/blender-git/blender/intern/cycles/kernel/kernel_path.h:541)
ccl::kernel_path_trace(ccl::KernelGlobals * kg, float * buffer, int sample, int x, int y, int offset, int stride) (/home/jacques/blender-git/blender/intern/cycles/kernel/kernel_path.h:673)
ccl::kernel_cpu_avx2_path_trace(ccl::KernelGlobals * kg, float * buffer, int sample, int x, int y, int offset, int stride) (/home/jacques/blender-git/blender/intern/cycles/kernel/kernels/cpu/kernel_cpu_impl.h:90)
ccl::CPUDevice::path_trace(ccl::CPUDevice * const this, ccl::DeviceTask & task, ccl::RenderTile & tile, ccl::KernelGlobals * kg) (/home/jacques/blender-git/blender/intern/cycles/device/device_cpu.cpp:845)
ccl::CPUDevice::thread_render(ccl::CPUDevice * const this, ccl::DeviceTask & task) (/home/jacques/blender-git/blender/intern/cycles/device/device_cpu.cpp:927)
ccl::CPUDevice::thread_run(ccl::CPUDevice * const this, ccl::DeviceTask * task) (/home/jacques/blender-git/blender/intern/cycles/device/device_cpu.cpp:506)
std::__invoke_impl<void, void (ccl::CPUDevice::*&)(ccl::DeviceTask*), ccl::CPUDevice*&, ccl::CPUDevice::CPUDeviceTask*&>(void (ccl::CPUDevice::*&)(ccl::CPUDevice * const, ccl::DeviceTask *) __f, ccl::CPUDevice *& __t,  __args#0) (/usr/include/c++/7/bits/invoke.h:73)
std::__invoke<void (ccl::CPUDevice::*&)(ccl::DeviceTask*), ccl::CPUDevice*&, ccl::CPUDevice::CPUDeviceTask*&>(void (ccl::CPUDevice::*&)(ccl::CPUDevice * const, ccl::DeviceTask *) __fn,  __args#0,  __args#1) (/usr/include/c++/7/bits/invoke.h:95)
std::_Bind<void (ccl::CPUDevice::*(ccl::CPUDevice*, ccl::CPUDevice::CPUDeviceTask*))(ccl::DeviceTask*)>::__call<void, int&&, 0ul, 1ul>(std::tuple<int&&>&&, std::_Index_tuple<0ul, 1ul>)(std::_Bind<void (ccl::CPUDevice::*(ccl::CPUDevice*, ccl::CPUDevice::CPUDeviceTask*))(ccl::DeviceTask*)> * const this, std::tuple<int&&> && __args) (/usr/include/c++/7/functional:467)
std::_Bind<void (ccl::CPUDevice::*(ccl::CPUDevice*, ccl::CPUDevice::CPUDeviceTask*))(ccl::DeviceTask*)>::operator()<int, void>(int&&)(std::_Bind<void (ccl::CPUDevice::*(ccl::CPUDevice*, ccl::CPUDevice::CPUDeviceTask*))(ccl::DeviceTask*)> * const this,  __args#0) (/usr/include/c++/7/functional:551)
std::_Function_handler<void (int), std::_Bind<void (ccl::CPUDevice::*(ccl::CPUDevice*, ccl::CPUDevice::CPUDeviceTask*))(ccl::DeviceTask*)> >::_M_invoke(std::_Any_data const&, int&&)(const std::_Any_data & __functor,  __args#0) (/usr/include/c++/7/bits/std_function.h:316)
ccl::TaskScheduler::thread_run(int thread_id) (/home/jacques/blender-git/blender/intern/cycles/util/util_task.cpp:396)
std::__invoke_impl<void, void (*&)(int), int&>(void (*&)(int) __f,  __args#0) (/usr/include/c++/7/bits/invoke.h:60)
std::__invoke<void (*&)(int), int&>(void (*&)(int) __fn,  __args#0) (/usr/include/c++/7/bits/invoke.h:95)
std::_Bind<void (*(int))(int)>::__call<void, , 0ul>(std::tuple<>&&, std::_Index_tuple<0ul>)(std::_Bind<void (*(int))(int)> * const this, std::tuple<> && __args) (/usr/include/c++/7/functional:467)
std::_Bind<void (*(int))(int)>::operator()<, void>()(std::_Bind<void (*(int))(int)> * const this) (/usr/include/c++/7/functional:551)
std::_Function_handler<void (), std::_Bind<void (*(int))(int)> >::_M_invoke(std::_Any_data const&)(const std::_Any_data & __functor) (/usr/include/c++/7/bits/std_function.h:316)
std::function<void ()>::operator()() const(const std::function<void()> * const this) (/usr/include/c++/7/bits/std_function.h:706)
ccl::thread::run(void * arg) (/home/jacques/blender-git/blender/intern/cycles/util/util_thread.cpp:52)
std::__invoke_impl<void*, void* (*)(void*), ccl::thread*>(void *(*&&)(void *) __f,  __args#0) (/usr/include/c++/7/bits/invoke.h:60)
std::__invoke<void* (*)(void*), ccl::thread*>(void *(*&&)(void *) __fn,  __args#0) (/usr/include/c++/7/bits/invoke.h:96)
std::thread::_Invoker<std::tuple<void* (*)(void*), ccl::thread*> >::_M_invoke<0ul, 1ul>(std::thread::_Invoker<std::tuple<void* (*)(void*), ccl::thread*> > * const this) (/usr/include/c++/7/thread:234)
std::thread::_Invoker<std::tuple<void* (*)(void*), ccl::thread*> >::operator()(std::thread::_Invoker<std::tuple<void* (*)(void*), ccl::thread*> > * const this) (/usr/include/c++/7/thread:243)
std::thread::_State_impl<std::thread::_Invoker<std::tuple<void* (*)(void*), ccl::thread*> > >::_M_run(std::thread::_State_impl<std::thread::_Invoker<std::tuple<void* (*)(void*), ccl::thread*> > > * const this) (/usr/include/c++/7/thread:186)
libstdc++.so.6![Unknown/Just-In-Time compiled code] (Unknown Source:0)
libpthread.so.0!start_thread(void * arg) (/build/glibc-OTsEL5/glibc-2.27/nptl/pthread_create.c:463)
libc.so.6!clone() (/build/glibc-OTsEL5/glibc-2.27/sysdeps/unix/sysv/linux/x86_64/clone.S:95)
It is trying to evaluate the texture after it has been freed.
I'm not sure at which level there should be a lock. It seems like it should not be possible to call ccl::BlenderSession::synchronize while being in ccl::CPUDevice::thread_render. Could be totally wrong of course.
That is certainly a threading issue. I can have these two call stacks at the same time: ``` ccl::ImageManager::file_load_image<(OpenImageIO_v1_8::TypeDesc::BASETYPE)11, float, float>(ccl::ImageManager * const this, ccl::ImageManager::Image * img, ccl::ImageDataType type, int texture_limit, ccl::device_vector<float> & tex_img) (/home/jacques/blender-git/blender/intern/cycles/render/image.cpp:582) ccl::ImageManager::device_load_image(ccl::ImageManager * const this, ccl::Device * device, ccl::Scene * scene, ccl::ImageDataType type, int slot, ccl::Progress * progress) (/home/jacques/blender-git/blender/intern/cycles/render/image.cpp:829) std::__invoke_impl<void, void (ccl::ImageManager::*&)(ccl::Device*, ccl::Scene*, ccl::ImageDataType, int, ccl::Progress*), ccl::ImageManager*&, ccl::Device*&, ccl::Scene*&, ccl::ImageDataType&, unsigned long&, ccl::Progress*&>(void (ccl::ImageManager::*&)(ccl::ImageManager * const, ccl::Device *, ccl::Scene *, ccl::ImageDataType, int, ccl::Progress *) __f, ccl::ImageManager *& __t, __args#0, __args#1, __args#2, __args#3, __args#4) (/usr/include/c++/7/bits/invoke.h:73) std::__invoke<void (ccl::ImageManager::*&)(ccl::Device*, ccl::Scene*, ccl::ImageDataType, int, ccl::Progress*), ccl::ImageManager*&, ccl::Device*&, ccl::Scene*&, ccl::ImageDataType&, unsigned long&, ccl::Progress*&>(void (ccl::ImageManager::*&)(ccl::ImageManager * const, ccl::Device *, ccl::Scene *, ccl::ImageDataType, int, ccl::Progress *) __fn, __args#0, __args#1, __args#2, __args#3, __args#4, __args#5) (/usr/include/c++/7/bits/invoke.h:95) std::_Bind<void (ccl::ImageManager::*(ccl::ImageManager*, ccl::Device*, ccl::Scene*, ccl::ImageDataType, unsigned long, ccl::Progress*))(ccl::Device*, ccl::Scene*, ccl::ImageDataType, int, ccl::Progress*)>::__call<void, int&&, 0ul, 1ul, 2ul, 3ul, 4ul, 5ul>(std::tuple<int&&>&&, std::_Index_tuple<0ul, 1ul, 2ul, 3ul, 4ul, 5ul>)(std::_Bind<void (ccl::ImageManager::*(ccl::ImageManager*, ccl::Device*, ccl::Scene*, ccl::ImageDataType, long unsigned int, ccl::Progress*))(ccl::Device*, ccl::Scene*, ccl::ImageDataType, int, ccl::Progress*)> * const this, std::tuple<int&&> && __args) (/usr/include/c++/7/functional:467) std::_Bind<void (ccl::ImageManager::*(ccl::ImageManager*, ccl::Device*, ccl::Scene*, ccl::ImageDataType, unsigned long, ccl::Progress*))(ccl::Device*, ccl::Scene*, ccl::ImageDataType, int, ccl::Progress*)>::operator()<int, void>(int&&)(std::_Bind<void (ccl::ImageManager::*(ccl::ImageManager*, ccl::Device*, ccl::Scene*, ccl::ImageDataType, long unsigned int, ccl::Progress*))(ccl::Device*, ccl::Scene*, ccl::ImageDataType, int, ccl::Progress*)> * const this, __args#0) (/usr/include/c++/7/functional:551) std::_Function_handler<void (int), std::_Bind<void (ccl::ImageManager::*(ccl::ImageManager*, ccl::Device*, ccl::Scene*, ccl::ImageDataType, unsigned long, ccl::Progress*))(ccl::Device*, ccl::Scene*, ccl::ImageDataType, int, ccl::Progress*)> >::_M_invoke(std::_Any_data const&, int&&)(const std::_Any_data & __functor, __args#0) (/usr/include/c++/7/bits/std_function.h:316) std::function<void (int)>::operator()(int) const(const std::function<void(int)> * const this, __args#0) (/usr/include/c++/7/bits/std_function.h:706) ccl::TaskPool::wait_work(ccl::TaskPool * const this, ccl::TaskPool::Summary * stats) (/home/jacques/blender-git/blender/intern/cycles/util/util_task.cpp:98) ccl::ImageManager::device_load_builtin(ccl::ImageManager * const this, ccl::Device * device, ccl::Scene * scene, ccl::Progress & progress) (/home/jacques/blender-git/blender/intern/cycles/render/image.cpp:1074) ccl::BlenderSession::builtin_images_load(ccl::BlenderSession * const this) (/home/jacques/blender-git/blender/intern/cycles/blender/blender_session.cpp:1451) ccl::BlenderSession::synchronize(ccl::BlenderSession * const this, BL::Depsgraph & b_depsgraph_) (/home/jacques/blender-git/blender/intern/cycles/blender/blender_session.cpp:897) ccl::sync_func(PyObject * args) (/home/jacques/blender-git/blender/intern/cycles/blender/blender_python.cpp:399) libpython3.7m.so.1.0!_PyMethodDef_RawFastCallKeywords (Unknown Source:0) libpython3.7m.so.1.0!_PyCFunction_FastCallKeywords (Unknown Source:0) libpython3.7m.so.1.0!_PyEval_EvalFrameDefault (Unknown Source:0) pydevd_frame_evaluator.cpython-37m-x86_64-linux-gnu.so!__pyx_f_18_pydevd_frame_eval_22pydevd_frame_evaluator_get_bytecode_while_frame_eval(PyFrameObject * __pyx_v_frame_obj, int __pyx_v_exc) (/io/ptvsd/src/ptvsd/_vendored/pydevd/_pydevd_frame_eval/pydevd_frame_evaluator.c:7198) libpython3.7m.so.1.0![Unknown/Just-In-Time compiled code] (Unknown Source:0) libpython3.7m.so.1.0!_PyEval_EvalFrameDefault (Unknown Source:0) pydevd_frame_evaluator.cpython-37m-x86_64-linux-gnu.so!__pyx_f_18_pydevd_frame_eval_22pydevd_frame_evaluator_get_bytecode_while_frame_eval(PyFrameObject * __pyx_v_frame_obj, int __pyx_v_exc) (/io/ptvsd/src/ptvsd/_vendored/pydevd/_pydevd_frame_eval/pydevd_frame_evaluator.c:7198) ``` and ``` ccl::TextureInterpolator<float>::interp_3d_linear(float z, float y, float x, const ccl::TextureInfo & info) (/home/jacques/blender-git/blender/intern/cycles/kernel/kernels/cpu/kernel_cpu_image.h:338) ccl::TextureInterpolator<float>::interp_3d(ccl::InterpolationType interp, float z, float y, float x, const ccl::TextureInfo & info) (/home/jacques/blender-git/blender/intern/cycles/kernel/kernels/cpu/kernel_cpu_image.h:461) ccl::kernel_tex_image_interp_3d(ccl::KernelGlobals * kg, int id, float x, float y, float z, ccl::InterpolationType interp) (/home/jacques/blender-git/blender/intern/cycles/kernel/kernels/cpu/kernel_cpu_image.h:510) ccl::volume_attribute_float(ccl::KernelGlobals * kg, const ccl::ShaderData * sd, const ccl::AttributeDescriptor desc) (/home/jacques/blender-git/blender/intern/cycles/kernel/geom/geom_volume.h:57) ccl::primitive_volume_attribute_float(const ccl::AttributeDescriptor desc, const ccl::ShaderData * sd, ccl::KernelGlobals * kg) (/home/jacques/blender-git/blender/intern/cycles/kernel/geom/geom_primitive.h:86) ccl::svm_node_principled_volume(ccl::KernelGlobals * kg, ccl::ShaderData * sd, float * stack, ccl::uint4 node, ccl::ShaderType shader_type, int path_flag, int * offset) (/home/jacques/blender-git/blender/intern/cycles/kernel/svm/svm_closure.h:1062) ccl::svm_eval_nodes(ccl::KernelGlobals * kg, ccl::ShaderData * sd, ccl::PathState * state, ccl::ShaderType type, int path_flag) (/home/jacques/blender-git/blender/intern/cycles/kernel/svm/svm.h:357) ccl::shader_eval_volume(int path_flag, ccl::VolumeStack * stack, ccl::PathState * state, ccl::ShaderData * sd, ccl::KernelGlobals * kg) (/home/jacques/blender-git/blender/intern/cycles/kernel/kernel_shader.h:1318) ccl::volume_shader_sample(ccl::VolumeShaderCoefficients * coeff, ccl::float3 P, ccl::PathState * state, ccl::ShaderData * sd, ccl::KernelGlobals * kg) (/home/jacques/blender-git/blender/intern/cycles/kernel/kernel_volume.h:67) ccl::kernel_volume_decoupled_record(ccl::KernelGlobals * kg, ccl::PathState * state, ccl::Ray * ray, ccl::ShaderData * sd, ccl::VolumeSegment * segment, bool heterogeneous) (/home/jacques/blender-git/blender/intern/cycles/kernel/kernel_volume.h:806) ccl::kernel_path_volume(ccl::PathRadiance * L, ccl::ShaderData * emission_sd, bool hit, ccl::Intersection * isect, ccl::float3 * throughput, ccl::Ray * ray, ccl::PathState * state, ccl::ShaderData * sd, ccl::KernelGlobals * kg) (/home/jacques/blender-git/blender/intern/cycles/kernel/kernel_path.h:184) ccl::kernel_path_integrate(ccl::ShaderData * emission_sd, float * buffer, ccl::PathRadiance * L, ccl::Ray * ray, ccl::float3 throughput, ccl::PathState * state, ccl::KernelGlobals * kg) (/home/jacques/blender-git/blender/intern/cycles/kernel/kernel_path.h:541) ccl::kernel_path_trace(ccl::KernelGlobals * kg, float * buffer, int sample, int x, int y, int offset, int stride) (/home/jacques/blender-git/blender/intern/cycles/kernel/kernel_path.h:673) ccl::kernel_cpu_avx2_path_trace(ccl::KernelGlobals * kg, float * buffer, int sample, int x, int y, int offset, int stride) (/home/jacques/blender-git/blender/intern/cycles/kernel/kernels/cpu/kernel_cpu_impl.h:90) ccl::CPUDevice::path_trace(ccl::CPUDevice * const this, ccl::DeviceTask & task, ccl::RenderTile & tile, ccl::KernelGlobals * kg) (/home/jacques/blender-git/blender/intern/cycles/device/device_cpu.cpp:845) ccl::CPUDevice::thread_render(ccl::CPUDevice * const this, ccl::DeviceTask & task) (/home/jacques/blender-git/blender/intern/cycles/device/device_cpu.cpp:927) ccl::CPUDevice::thread_run(ccl::CPUDevice * const this, ccl::DeviceTask * task) (/home/jacques/blender-git/blender/intern/cycles/device/device_cpu.cpp:506) std::__invoke_impl<void, void (ccl::CPUDevice::*&)(ccl::DeviceTask*), ccl::CPUDevice*&, ccl::CPUDevice::CPUDeviceTask*&>(void (ccl::CPUDevice::*&)(ccl::CPUDevice * const, ccl::DeviceTask *) __f, ccl::CPUDevice *& __t, __args#0) (/usr/include/c++/7/bits/invoke.h:73) std::__invoke<void (ccl::CPUDevice::*&)(ccl::DeviceTask*), ccl::CPUDevice*&, ccl::CPUDevice::CPUDeviceTask*&>(void (ccl::CPUDevice::*&)(ccl::CPUDevice * const, ccl::DeviceTask *) __fn, __args#0, __args#1) (/usr/include/c++/7/bits/invoke.h:95) std::_Bind<void (ccl::CPUDevice::*(ccl::CPUDevice*, ccl::CPUDevice::CPUDeviceTask*))(ccl::DeviceTask*)>::__call<void, int&&, 0ul, 1ul>(std::tuple<int&&>&&, std::_Index_tuple<0ul, 1ul>)(std::_Bind<void (ccl::CPUDevice::*(ccl::CPUDevice*, ccl::CPUDevice::CPUDeviceTask*))(ccl::DeviceTask*)> * const this, std::tuple<int&&> && __args) (/usr/include/c++/7/functional:467) std::_Bind<void (ccl::CPUDevice::*(ccl::CPUDevice*, ccl::CPUDevice::CPUDeviceTask*))(ccl::DeviceTask*)>::operator()<int, void>(int&&)(std::_Bind<void (ccl::CPUDevice::*(ccl::CPUDevice*, ccl::CPUDevice::CPUDeviceTask*))(ccl::DeviceTask*)> * const this, __args#0) (/usr/include/c++/7/functional:551) std::_Function_handler<void (int), std::_Bind<void (ccl::CPUDevice::*(ccl::CPUDevice*, ccl::CPUDevice::CPUDeviceTask*))(ccl::DeviceTask*)> >::_M_invoke(std::_Any_data const&, int&&)(const std::_Any_data & __functor, __args#0) (/usr/include/c++/7/bits/std_function.h:316) std::function<void (int)>::operator()(int) const(const std::function<void(int)> * const this, __args#0) (/usr/include/c++/7/bits/std_function.h:706) ccl::TaskScheduler::thread_run(int thread_id) (/home/jacques/blender-git/blender/intern/cycles/util/util_task.cpp:396) std::__invoke_impl<void, void (*&)(int), int&>(void (*&)(int) __f, __args#0) (/usr/include/c++/7/bits/invoke.h:60) std::__invoke<void (*&)(int), int&>(void (*&)(int) __fn, __args#0) (/usr/include/c++/7/bits/invoke.h:95) std::_Bind<void (*(int))(int)>::__call<void, , 0ul>(std::tuple<>&&, std::_Index_tuple<0ul>)(std::_Bind<void (*(int))(int)> * const this, std::tuple<> && __args) (/usr/include/c++/7/functional:467) std::_Bind<void (*(int))(int)>::operator()<, void>()(std::_Bind<void (*(int))(int)> * const this) (/usr/include/c++/7/functional:551) std::_Function_handler<void (), std::_Bind<void (*(int))(int)> >::_M_invoke(std::_Any_data const&)(const std::_Any_data & __functor) (/usr/include/c++/7/bits/std_function.h:316) std::function<void ()>::operator()() const(const std::function<void()> * const this) (/usr/include/c++/7/bits/std_function.h:706) ccl::thread::run(void * arg) (/home/jacques/blender-git/blender/intern/cycles/util/util_thread.cpp:52) std::__invoke_impl<void*, void* (*)(void*), ccl::thread*>(void *(*&&)(void *) __f, __args#0) (/usr/include/c++/7/bits/invoke.h:60) std::__invoke<void* (*)(void*), ccl::thread*>(void *(*&&)(void *) __fn, __args#0) (/usr/include/c++/7/bits/invoke.h:96) std::thread::_Invoker<std::tuple<void* (*)(void*), ccl::thread*> >::_M_invoke<0ul, 1ul>(std::thread::_Invoker<std::tuple<void* (*)(void*), ccl::thread*> > * const this) (/usr/include/c++/7/thread:234) std::thread::_Invoker<std::tuple<void* (*)(void*), ccl::thread*> >::operator()(std::thread::_Invoker<std::tuple<void* (*)(void*), ccl::thread*> > * const this) (/usr/include/c++/7/thread:243) std::thread::_State_impl<std::thread::_Invoker<std::tuple<void* (*)(void*), ccl::thread*> > >::_M_run(std::thread::_State_impl<std::thread::_Invoker<std::tuple<void* (*)(void*), ccl::thread*> > > * const this) (/usr/include/c++/7/thread:186) libstdc++.so.6![Unknown/Just-In-Time compiled code] (Unknown Source:0) libpthread.so.0!start_thread(void * arg) (/build/glibc-OTsEL5/glibc-2.27/nptl/pthread_create.c:463) libc.so.6!clone() (/build/glibc-OTsEL5/glibc-2.27/sysdeps/unix/sysv/linux/x86_64/clone.S:95) ``` It is trying to evaluate the texture after it has been freed. I'm not sure at which level there should be a lock. It seems like it should not be possible to call `ccl::BlenderSession::synchronize` while being in `ccl::CPUDevice::thread_render`. Could be totally wrong of course.
Added subscriber: @christopher.burns
Added subscribers: @WhitecloudFX, @brecht
This issue was referenced by blender/cycles@07a5c28875
This issue was referenced by blender/cycles@07a5c2887504f79243b5edc2fa00eb582e89928f
This issue was referenced by 424566239f
This issue was referenced by 424566239fe97c268061e8b375029b59a5ea010f
Added subscriber: @FATTOMCAT
5 Participants
Reference: blender/blender#62121
