Vertex/Edge/Polygon selection with python not functioning as it used to #62164
Closed
opened 2019-03-04 02:13:02 +01:00 by Cody Winchester · 5 comments
Operating system: Windows 10
Broken: Blender 2.80 ae977d13f8
When trying to set a vertex or edge or polygon selection to False "bpy.context.object.data.vertices- [x].select = False" it does not work if any of the edges or polygons connected to the vertex are selected. If all vertices are selected in a mesh and you want to unselect 1 vertex then you need to also unselect every connected edge and polygon or else it will not work.
With default blend file:
1 - Select the default cube
2 - Go into editmode and ensure all vertices are selected
3 - Exit editmode
4 - In the python console type "C.object.data.vertices- [x].select = False"
5 - Go into editmode and all vertices will remain selected
**System Information** Operating system: Windows 10 **Blender Version** Broken: Blender 2.80 ae977d13f8e9 **Short description of error** When trying to set a vertex or edge or polygon selection to False "bpy.context.object.data.vertices- [x].select = False" it does not work if any of the edges or polygons connected to the vertex are selected. If all vertices are selected in a mesh and you want to unselect 1 vertex then you need to also unselect every connected edge and polygon or else it will not work. **Exact steps for others to reproduce the error** With default blend file: 1 - Select the default cube 2 - Go into editmode and ensure all vertices are selected 3 - Exit editmode 4 - In the python console type "C.object.data.vertices- [x].select = False" 5 - Go into editmode and all vertices will remain selected
Added subscriber: @CodyWinchester
Member
Added subscribers: @ideasman42, @JacquesLucke
Member
Could not figure out where the error happens yet.
Should be somewhere in the Mesh->BMesh conversion, but that is only a guess.
@ideasman42, I still have some trouble debugging the bmesh data structure. Are there utilities that allow me to e.g. easily print the state of a bmesh?
Could not figure out where the error happens yet. Should be somewhere in the Mesh->BMesh conversion, but that is only a guess. @ideasman42, I still have some trouble debugging the bmesh data structure. Are there utilities that allow me to e.g. easily print the state of a bmesh?
Campbell Barton self-assigned this 2019-03-04 12:23:59 +01:00
This isn't a bug exactly, accessing selection per element just doesn't support flushing.
If you want to manipulate selection in a way that flushes changes between elements, use BMesh and use BMVert.select_set method.
Currently Blender doesn't have a useful/complete API to manipulate & flush selection outside of edit-mode.
This isn't a bug exactly, accessing selection per element just doesn't support flushing. If you want to manipulate selection in a way that flushes changes between elements, use BMesh and use `BMVert.select_set` method. Currently Blender doesn't have a useful/complete API to manipulate & flush selection outside of edit-mode.
Reference: blender/blender#62164
