Drivers that use modified namespaces only work after reloading twice blender files with the same internal script #62195
Reference: blender/blender#62195
Operating system: Ubuntu 18.04.1
Graphics card: RX 480
Broken:
blender-2.80-3730d16347a5-2019-03-04, 16:04
Worked:
Open the file twice
Drivers that use modified namespaces only work after reloading twice blender files with the same internal script.
I made an empty with saturation and hue object properties, these properties are later plugged into a light's RGB values using drivers, (in this case, for cycles and eevee), for this purpose a script is used that adds an entry to the driver's namespace to convert hue and saturation into RGB. I make sure this script is registered and that blender auto-runs python files.
Lights sync eevee and cycles.blend
Added subscriber: @iszotic
I don't know what to do in this file exactly to see the issue.
Can you create an even simpler example? Maybe just a simple driver on the object location?
I tried to make it as simply as possible, 3 drivers controlling the RGB channels of one light, with 2 properties in one empty and one script appending a function to the namespace, also appended a video.
Bug-demo.mkv
Added subscriber: @brecht
The problem is that the depsgraph is build before your script executes. Both happens in
wm_file_read_post
, but in the "wrong" order.I'm not aware of any non-hacky solution to solve this currently.
The cleanest solution would probably be to make the
Register
option for text blocks a bit more advanced. For example, allowing to run the script before or after depsgraph evaluation. Even more options like running a script on frame change etc. could be possible. All the event handlers we have basically.@brecht, can you think of a case when it is useful to run the script after the depsgraph has been build? Setting up e.g. driver namespaces seems to be one of the most important use cases for this auto-run feature.
This is probably the same as #61063 (Function from Python not being loaded for Driver when project opened),
This issue was referenced by
d31b2f8549
