Crash moving around the veiwport in wireframe
Operating system: Windows 10
Graphics card: NVIDIA GeForce940MX
Broken: 2.80release 1df6a98b176f
Worked:
while rotating in wireframe view wiht dense topology in blender crashes after "LMB setting " the 3d cursor
open the attached blend file, toggle into wireframe view, zoom up to a dense part of the mesh, rotate 3d the view, afterwards, click on an empty space on the screen or try to click to change the 3d cursor and immediately a crash should happen.
try if you get crash even by starting blender with this:
--debug-gpu-force-workarounds
is this put in through the run function via the desktop or the blender.exe startup window? if it put in the startup, where should it be written?
select the blender folder, shift+ rigtclick mouse --> menu open cmd/powershell
on cmd:
blender.exe --debug-gpu-force-workarounds
Sebastian Parborg (zeddb) triaged this task as Needs Information from User priority.
You should also make sure that you have the latest nvidia drivers for your card.
Philipp Oeser (lichtwerk) closed this task as Archived.
