Changing key values in graph editor has no effect to keyed object values in viewport
Operating system: Windows 10 Pro 64
Graphics card: GeForce GTX 1080 Ti
Broken: v2.80.47
Date: 2019-03-07 11:23 Hash: a280867ac2ed
When changing an active keyframe value by typing it in the graph editor, the changes will not be synched with corresponding keyed object values.
  1. Open attached scene
  2. Select one of the key frames in Graph Editor.
  3. In F-Curve properties tab on the right hand, click into Active Keyframe->Key->Value and type in another value.
Result: nothing happen. The correspondig rotation value in the object properties rotation field doesn't refresh.
Jacques Lucke (JacquesLucke) triaged this task as Confirmed, Medium priority.
Checking...
Thank you Jacques!
Now all kind of inputs in graph editor should be updated right?
(Not just my example with rotation.)
This is only a potential fix, it is not merged into master yet.
But yes, this fix should work with any property, not just with your example.
