"Repeat History" unavailable after "Undo"
Confirmed, LowPublicTO DO
Currently undo clears the operator history,
ideally this should instead keep these actions in sync with the undo history.
Related Objects
noki paike (amonpaike) updated the task description. (Show Details)
William Reynish (billreynish) lowered the priority of this task from 90 to 50.Mar 7 2019, 8:13 PM
I can confirm this here too.
(Although, in the future, please fill out the bug report template correctly, and use normal spelling. Thanks)
man, you finally understood where my gaps are.
my english is not the best, otherwise I would have already conquered the world for a while now .
hahaha (kidding)
Richard Antalik (ISS) changed the task status from Confirmed to Needs Information from User.Fri, Jan 24, 9:44 PM
I have re-triaged this report and can not reproduce it.
Can you please check if this is still an issue in latest build?
https://builder.blender.org/download/
Campbell Barton (campbellbarton) renamed this task from "Repeat History" reset the list of actions if you make undo ctrl+z to "Repeat History" unavailable after "Undo".Mon, Feb 3, 8:31 AM
Campbell Barton (campbellbarton) triaged this task as Low priority.
Campbell Barton (campbellbarton) updated the task description. (Show Details)
Campbell Barton (campbellbarton) changed the subtype of this task from "Report" to "To Do".
As far as I can tell, this limitation has existed ever since repeat history was added. Marking as a TODO.
Campbell Barton (campbellbarton) changed the task status from Needs Information from User to Confirmed.Mon, Feb 3, 8:35 AM
