Grease pencil blank material slot #62384
9 Participants
Reference: blender/blender#62384
Operating system: Windows 10 (64 bit) OS build 17134.591
Graphics card: Graphics Chipset AMD Radeon(TM) R4 Graphics
Broken: Blender 2.80 Beta Windows 64 bit March 09, 01:09:33 -
a0f2923fd8
1# Pen settings and material properties tabs disappeared
2# An anonymous blank material comes out
From 2D animation default file, switch fill tool to draw tool and the pen properties will disappear. It'll only reappear once again when I reopen the .blend file.Anime-8.blend
Added subscriber: @HanafiHikari
Added subscriber: @ZedDB
In the future, please only report one issue per ticket.
In this case the first issue is a duplicate, so no need to report it again: #59445
I can see the second issue in your file, but you do not describe how you got it in the first place.
If I open up the default 2D animation file, that blank material is not there.
How did you managed to get the blank material?
@ZedDB I don't know exactly. But I am filling colour to my art and play around with the "Grey" and "Red" materials properties and press "+" button to add another material then weirdly it occurs.
@HanafiHikari could you provide a step by step guide?
Like this:
button@ZedDB No. It just appear randomly.
Added subscriber: @dfelinto
Please check
ba4d07cc5c
to see if it fixed the material issue.Added subscriber: @capnm
Fixed the "hidden" problem for me, but it (not sure if it was caused by your commit) behaves weird:
Step by step repro:
in a new slot at the bottom of the slot list:
Added subscriber: @antoniov
No, it's not magic.... I guess the current brush has assigned the "old" material, so when you draw a new stroke with this brush, the system check if the material is assigned to the objet, and add it if necessary.
Verify what material are you using in the current brush and verify also if the material is pinned to the brush.
It feels magic ;-)
I wrote the minimal example repro with a start from the factory settings, so you can verify everything yourself.
I believe the material setting is currently weird/broken. See e.g. at the 12 in the screenshot …
Added subscriber: @matc
The 'Add a new material' button in theory is a 'Replace with duplicate' button.
The 12 is likely caused by loading the .blend file. I can reproduce this with Grease Pencil -> Blank.
Here is one possible solution. Keeping the 'magic' in sync with the properties panel (immediately, instead of after the next stroke):
Another solution is to replicate the behviour of other objects.
I don't really know which one is the intended behaviour.
Edit:
Now I think the new material copy should be placed in a new slot. Without the material brush pin also set as current?
Is the pin option intentionally not present in the active tool settings?
Brush switching via the active tool settings is also not synchronized properly with the top bar. The brush name in top bar changes only after drawing in the viewport.
If you don't look at or hide the top bar (me), the GP materials panel is currently misleading, sorry for my confusion.
Thanks @matc for your code. I have committed one of your solutions (credits to you). The good one is update the brush using BKE_brush_update.
I have seen there are still some problems with the user number for the autocreated materials. I will take a look on that too.
Added subscriber: @mendio
@mendio Can you verify the template design? it looks there are enough screen space in the example above.
Removed subscriber: @matc
2D workspace Bugsto Grease pencil blank material slotThe screenshots I see in this task are frome the old 2D animation template @antoniov , what do you want me to check?
Added subscriber: @brecht
I don't think there's anything to do regarding bug #1 and the template anymore.
I just renamed the report to try to make it clear this is only about #2 now, some issue with empty material slots.
This issue was referenced by
b46c21364a
