opensubdiv crash in rendered viewport #62408
6 Participants
Reference: blender/blender#62408
Operating system: Mageia Cauldron (Mageia 7)
Graphics card: Display on AMD A10-Kaveri with amdgpu kernel driver and radeonsi Mesa
CUDA Render on Nvidia GTX1050Ti
Broken:Blender 2.79 (sub 6), Commit date: 2019-01-09 22:04, Hash
5100e4419e
(example: 2.79b release)
(example: 2.80,
edbf15d3c0
, blender2.8, 2018-11-28, as found on the splash screen)Worked: (optional) blender-2.79b-linux-glibc219-x86_64/2.79 Hash
f4dc9f9d68
and
blender-2.79-e6acb4fba094-linux-glibc224-x86_64 2019-01-04 11:41 Hash
e6acb4fba0
Selecting Display rendered preview in 3D View window causes immediate crash if Experimental, Adaptive Subdivision modifier is used on model.lores-torus-tyre-crashtest.blend
With attached file, using any Blender 2.79 released after 2019-01-10, using CPU or GPU rendering, change the 3D View window to display as rendered.
Added subscriber: @jaywalker
Added subscriber: @GavinScott
It renders for me OK the first time, but if I toggle back and forth between rendered and lookdev modes it locks up in a memory allocation loop.
I suspect this is the same issue as in my https://developer.blender.org/T60379 which still needs some developer TLC (hint, hint, wink, wink, nudge, nudge).
Hi Gavin, your memory allocation loop sounds familiar. I have seen it in 2.79 also. It happens when I load either your disptest.blend or the test file above into yesterday's 2.80, but 2.80 does not crash.
2.79 does, with opensubdiv 3.3.3, and doesn't crash if compiled without osd support, or if Experimental features are disabled in the render settings, so no adaptive subdivision.
Added subscribers: @Sergey, @ZedDB
I can not reproduce this crash with my 2.79 build (with opensubdiv 3.3.3). And as you stated, I can not reproduce the crash either in 2.8.
@Sergey can you reproduce this on 2.79?
This does happen with own builds of blender2.7 and master branch, and with builds from buildbot.
Think you're more familiar with the opensubdiv code in Cycles.
If it's not Cycles specific, please bounce back.
As with my #60379 I presume that adaptive subdiv is complex in that the adaptive tessellation needs to be successfully recomputed basically whenever anything affecting the view or the subdiv modifier or the associated scene parameters change, and there are one or more issues with this, either dependency handling, or simply managing the reset of the adaptive tessellation stuff when things change and/or making sure that the computation has completed successfully before trying to do things based on that.
This issue was referenced by blender/cycles@43894c48cc
8982f0cfee
Thanks for the fix, Brecht. I completed a Blender RPM rebuild yesterday using all system libraries, so some versions differ from the Blender.org dailies. In particular I have LLVM 8.0 and OSL 1.11.0 but essentially my OSD version is still 3.3.3.
I can confirm that this fix cures my problem of the Blender crash when rendering in the viewport models using adaptive subdivision .
Richard
