inconsistency in shader nodes when opening .blend vs. append in 2.8. Node conversion skipped when object is appended. #62415
5 Participants
Reference: blender/blender#62415
Operating system:
Graphics card: 2x 2080TI
(2.79b
f4dc9f9d68
, blender2.79b, 2018-03-22)(2.80,
a280867ac2
, blender2.8, 2019-03-07, as found on the splash screen)I have models (.blend files) that were created in 2.79 cycles. When attempting to open them in 2.8 I see some nodes are reconfigured, 2.79a (where Displacement was a scalar socket) and 2.8 (where Displacement is a Vector), Blender automatically replaces the "RGB to BW" node connected to the material output with a proper normalmap displacement node setup.
However, unlike opening, instead, when appending from that same file, 2.8 will not reconfigure the shaders, It retains the same node configuration as from 2.79 resulting in displacement looking blocky and incorrect: https://i.stack.imgur.com/LrXpx.png
Here is my StackOverflow post explaining in more detail and with images of the node configurations.
Also, I was able to write a script that can be run just after appending objects into the scene. It will replace the nodes linked to the Material Output node with a proper displacement node setup. This resembles the way it would have been converted as if the object were opened instead of being appended.
FixDisplacementNodes.py
Added subscriber: @blended_blue
#62881 was marked as duplicate of this issue
inconsistency in shaders nodes when opening .blend vs. append/link in 2.8. Node conversions are skipped when appending.to inconsistency in shader nodes when opening .blend vs. append/link in 2.8. Node conversion skipped when object is appended.Added subscriber: @ZedDB
Can you attach a minimal 2.79 .blend file? My 2.79 builds are too new so they have converted to vector output there too.
Added subscriber: @lichtwerk
Can confirm. (for appending, if you link in the object it works after saving/reloading).
A fix was recently done for linking (in the fix for #54504).
Not even sure if do_version() runs for appending..., checking...
inconsistency in shader nodes when opening .blend vs. append/link in 2.8. Node conversion skipped when object is appended.to inconsistency in shader nodes when opening .blend vs. append in 2.8. Node conversion skipped when object is appended.Turns out
do_versions()
is run in blender when appending, but the corresponding python handler is not.And since cycles does its thing in a
bpy.app.handlers.version_update
this wont be called.D4499 is a possible solution
Added subscriber: @YegorSmirnov
This issue was referenced by blender/cycles@0f2c51ffb9
cc5a75d572
Added subscriber: @brecht
@brecht: thank you!
