Wrong color distribution on the UV-strech map
Open, Confirmed, LowPublic
Broken: 2.80 (sub 47), a0f2923fd821, 2019-03-08 21:52
The problem is on the picture.
Perhaps it caused by arithmetic mean or another wrong function for color calculation: so three vertices, that not distorted are affects much more then one hardly displaced.
Perhaps it should count area or difference between edge-length and difference between angles on the geometry and on the UV.
IDK if it is bug or wrong choice of function, but it is obvious, that such map do not show actual problem with red.
Brecht Van Lommel (brecht) lowered the priority of this task from Confirmed, Medium to Confirmed, Low.
It seems to display the same way in 2.7.
The algorithm could probably be improved here, the main issue I see is that the triangulation in the 3D viewport does not match the one in the UV editor.
