after selecting material tab blender crash
Closed, DuplicatePublic
Operating system: Windows-10-10.0.16299 64 Bits
Graphics card: Intel(R) HD Graphics 4000 Intel 4.0.0 - Build 10.18.10.4358
6 GB RAM
Broken: version: 2.80 (sub 48), branch: master, commit date: 2019-03-14 17:14, hash: rB55e79d8f36c6
when selecting material then switch to other tab it not respond and crash.
after selecting the material tab to chose a material and then selecting any other tab like modifier it stuck on it and cant switch to it then blender not respond it after that it crash.
William Reynish (billreynish) lowered the priority of this task from Needs Triage by Developer to Needs Information from User.Mar 15 2019, 9:02 AM
Does this happen if you set the renderer to Cycles?
It could be related to Eevee material preview generation.
is just happen on eevee.
E:\BLENDER\BLENDER-VESRSIONS\blender-2.80>blender --debug-gpu
Read prefs: C:\Users\ad4k2\AppData\Roaming\Blender Foundation\Blender\2.80\config\userpref.blend
GPUTexture: create : TEXTURE_CUBE_MAP, RGBA16F, w : 2, h : 2, d : 0, comp : 4, size : 0.00 MiB
GPUTexture: create : TEXTURE_1D, RGBA8, w : 1, h : 0, d : 0, comp : 4, size : 0.00 MiB
GPUTexture: create : TEXTURE_2D, RGBA8, w : 1, h : 1, d : 0, comp : 4, size : 0.00 MiB
GPUTexture: create : TEXTURE_3D, RGBA8, w : 1, h : 1, d : 1, comp : 4, size : 0.00 MiB
Using KHR_debug extension
GL application marker: Successfully hooked OpenGL debug callback.
found bundled python: E:\BLENDER\BLENDER-VESRSIONS\blender-2.80\2.80\python
GPUTexture: create : TEXTURE_2D, RGBA8, w : 961, h : 26, d : 0, comp : 4, size : 0.10 MiB
GPUTexture: create : TEXTURE_2D, R8, w : 16384, h : 128, d : 0, comp : 1, size : 2.00 MiB
GPUTexture: create : TEXTURE_2D, RGBA8, w : 405, h : 26, d : 0, comp : 4, size : 0.04 MiB
GPUTexture: create : TEXTURE_2D, RGBA8, w : 16, h : 32, d : 0, comp : 4, size : 0.00 MiB
GPUTexture: create : TEXTURE_2D, RGBA8, w : 1350, h : 32, d : 0, comp : 4, size : 0.16 MiB
GPUTexture: create : TEXTURE_2D, RGBA8, w : 1366, h : 20, d : 0, comp : 4, size : 0.10 MiB
GPUTexture: create : TEXTURE_2D, RGBA8, w : 237, h : 26, d : 0, comp : 4, size : 0.02 MiB
GPUTexture: create : TEXTURE_2D, RGBA8, w : 29, h : 404, d : 0, comp : 4, size : 0.04 MiB
GPUTexture: create : TEXTURE_2D, RGBA8, w : 208, h : 404, d : 0, comp : 4, size : 0.32 MiB
GPUTexture: create : TEXTURE_2D, RGBA8, w : 237, h : 178, d : 0, comp : 4, size : 0.16 MiB
GL API performance: Vertex shader recompiled due to state change.
GPUTexture: create : TEXTURE_2D, RGBA8, w : 1128, h : 26, d : 0, comp : 4, size : 0.11 MiB
GPUTexture: create : TEXTURE_2D, RGBA8, w : 1128, h : 22, d : 0, comp : 4, size : 0.09 MiB
GL API deprecated behavior: Wide lines have been deprecated. glLineWidth set to 2.000000. glLineWidth with width greater than 1.0 will generate GL_INVALID_VALUE error in future versions
GPUTexture: create : TEXTURE_2D, RGBA8, w : 56, h : 560, d : 0, comp : 4, size : 0.12 MiB
GPUTexture: create : TEXTURE_2D, RGBA8, w : 1128, h : 586, d : 0, comp : 4, size : 2.52 MiB
GPUTexture: create : TEXTURE_2D, DEPTH24_STENCIL8, w : 1128, h : 586, d : 0, comp : 1, size : 2.52 MiB
GPUTexture: create : TEXTURE_1D, RGBA8, w : 257, h : 0, d : 0, comp : 4, size : 0.00 MiB
GPUTexture: create : TEXTURE_1D, RGBA8, w : 256, h : 0, d : 0, comp : 4, size : 0.00 MiB
GPUTexture: create : TEXTURE_2D, R11F_G11F_B10F, w : 1128, h : 586, d : 0, comp : 3, size : 2.52 MiB
GPUTexture: create : TEXTURE_2D, R32UI, w : 1128, h : 586, d : 0, comp : 1, size : 2.52 MiB
GPUTexture: create : TEXTURE_2D, RG16, w : 1128, h : 586, d : 0, comp : 2, size : 2.52 MiB
GPUTexture: create : TEXTURE_2D, RGBA16F, w : 64, h : 64, d : 0, comp : 4, size : 0.06 MiB
GPUTexture: create : TEXTURE_2D, RGBA8, w : 16, h : 16, d : 0, comp : 4, size : 0.00 MiB
GPUTexture: create : TEXTURE_2D, DEPTH_COMPONENT24, w : 1128, h : 586, d : 0, comp : 1, size : 1.89 MiB
GPUTexture: create : TEXTURE_2D, R16UI, w : 1128, h : 586, d : 0, comp : 1, size : 1.26 MiB
GPUTexture: create : TEXTURE_2D, R8, w : 16384, h : 64, d : 0, comp : 1, size : 1.00 MiB
GPUTexture: create : TEXTURE_2D, RGBA8, w : 527, h : 491, d : 0, comp : 4, size : 0.99 MiB
\BLENDER\BLENDER-VESRSIONS\blender-2.80>blender --debug-gpu --debug-gpu-force-workarounds
GPU: Bypassing workaround detection.
GPU: OpenGL identification strings
GPU: vendor: Intel
GPU: renderer: Intel(R) HD Graphics 4000
GPU: version: 4.0.0 - Build 10.18.10.4358
GPUTexture: create : TEXTURE_2D, DEPTH32F_STENCIL8, w : 1128, h : 586, d : 0, comp : 1, size : 5.04 MiB
Saved session recovery to 'E:\BLENDER\TEMP\quit.blend'
Blender quit
system info
Blender 2.80 (sub 50) System Information
Blender:
version: 2.80 (sub 50), branch: master, commit date: 2019-03-18 21:39, hash: d47f827019f2, type: Release
build date: 18/03/2019, 18:02
platform: Windows
binary path: 'E:\\BLENDER\\BLENDER-VESRSIONS\\blender-2.80\\blender.exe'
build cflags: /W3 /w34062 /w34189 /wd4018 /wd4146 /wd4065 /wd4127 /wd4181 /wd4200 /wd4244 /wd4267 /wd4305 /wd4800 /wd4828 /wd4996 /we4013 /we4133 /we4431 /w35038 /DWIN32 /D_WINDOWS /W3 /nologo /J /Gd /MP -openmp
build cxxflags: /W3 /w34062 /w34189 /wd4018 /wd4146 /wd4065 /wd4127 /wd4181 /wd4200 /wd4244 /wd4267 /wd4305 /wd4800 /wd4828 /wd4996 /we4013 /we4133 /we4431 /w35038 /DWIN32 /D_WINDOWS /W3 /GR /EHsc /nologo /J /Gd /MP /EHsc -openmp
build linkflags: /MACHINE:X64 /SUBSYSTEM:CONSOLE /STACK:2097152 /INCREMENTAL:NO /NODEFAULTLIB:msvcrt.lib /NODEFAULTLIB:msvcmrt.lib /NODEFAULTLIB:msvcurt.lib /NODEFAULTLIB:msvcrtd.lib /ignore:4049 /ignore:4217 /ignore:4221
build system: CMake
Python:
version: 3.7.0 (default, Aug 26 2018, 16:05:01) [MSC v.1900 64 bit (AMD64)]
paths:
'E:\\BLENDER\\BLENDER-VESRSIONS\\blender-2.80\\2.80\\scripts\\addons_contrib'
'E:\\BLENDER\\BLENDER-VESRSIONS\\blender-2.80\\2.80\\scripts\\addons'
'E:\\BLENDER\\BLENDER-VESRSIONS\\blender-2.80\\2.80\\scripts\\startup'
'E:\\BLENDER\\BLENDER-VESRSIONS\\blender-2.80\\2.80\\scripts\\modules'
'E:\\BLENDER\\BLENDER-VESRSIONS\\blender-2.80\\python37.zip'
'E:\\BLENDER\\BLENDER-VESRSIONS\\blender-2.80\\2.80\\python\\DLLs'
'E:\\BLENDER\\BLENDER-VESRSIONS\\blender-2.80\\2.80\\python\\lib'
'E:\\BLENDER\\BLENDER-VESRSIONS\\blender-2.80'
'E:\\BLENDER\\BLENDER-VESRSIONS\\blender-2.80\\2.80\\python'
'E:\\BLENDER\\BLENDER-VESRSIONS\\blender-2.80\\2.80\\python\\lib\\site-packages'
'E:\\BLENDER\\BLENDER-VESRSIONS\\blender-2.80\\2.80\\scripts\\freestyle\\modules'
'E:\\BLENDER\\BLENDER-VESRSIONS\\blender-2.80\\2.80\\scripts\\addons\\modules'
'C:\\Users\\ad4k2\\AppData\\Roaming\\Blender Foundation\\Blender\\2.80\\scripts\\addons\\modules'
Python (External Binary):
binary path: 'E:\\BLENDER\\BLENDER-VESRSIONS\\blender-2.80\\2.80\\python\\bin\\python.EXE'
version: Python 3.7.0
Directories:
scripts:
'E:\\BLENDER\\BLENDER-VESRSIONS\\blender-2.80\\2.80\\scripts'
user scripts: 'C:\\Users\\ad4k2\\AppData\\Roaming\\Blender Foundation\\Blender\\2.80\\scripts'
pref scripts: None
datafiles: 'C:\\Users\\ad4k2\\AppData\\Roaming\\Blender Foundation\\Blender\\2.80\\datafiles\\'
config: 'C:\\Users\\ad4k2\\AppData\\Roaming\\Blender Foundation\\Blender\\2.80\\config\\'
scripts : 'C:\\Users\\ad4k2\\AppData\\Roaming\\Blender Foundation\\Blender\\2.80\\scripts\\'
autosave: 'C:\\Users\\ad4k2\\AppData\\Roaming\\Blender Foundation\\Blender\\2.80\\autosave\\'
tempdir: 'E:\\BLENDER\\TEMP\\blender_a09348\\'
FFmpeg:
avcodec: '58, 18, 100'
avdevice: '58, 3, 100'
avformat: '58, 12, 100'
avutil: '56, 14, 100'
swscale: ' 5, 1, 100'
SDL:
Version: 2.0.8
Loading method: linked (WITH_SDL_DYNLOAD=OFF)
Other Libraries:
OpenColorIO: 1, 1, 0
OpenImageIO: 1, 8, 13
OpenShadingLanguage: 1, 9, 9
OpenSubdiv: 0, 0, 0
OpenVDB: 5, 1, 0
Alembic: 1, 7, 8
OpenGL:
renderer: 'Intel(R) HD Graphics 4000'
vendor: 'Intel'
version: '4.0.0 - Build 10.18.10.5059'
extensions:
GL_3DFX_texture_compression_FXT1
GL_ARB_ES2_compatibility
GL_ARB_ES3_compatibility
GL_ARB_arrays_of_arrays
GL_ARB_base_instance
GL_ARB_blend_func_extended
GL_ARB_buffer_storage
GL_ARB_color_buffer_float
GL_ARB_compatibility
GL_ARB_compressed_texture_pixel_storage
GL_ARB_conservative_depth
GL_ARB_copy_buffer
GL_ARB_debug_output
GL_ARB_depth_buffer_float
GL_ARB_depth_clamp
GL_ARB_depth_texture
GL_ARB_draw_buffers
GL_ARB_draw_buffers_blend
GL_ARB_draw_elements_base_vertex
GL_ARB_draw_indirect
GL_ARB_draw_instanced
GL_ARB_explicit_attrib_location
GL_ARB_fragment_coord_conventions
GL_ARB_fragment_program
GL_ARB_fragment_program_shadow
GL_ARB_fragment_shader
GL_ARB_framebuffer_no_attachments
GL_ARB_framebuffer_object
GL_ARB_framebuffer_sRGB
GL_ARB_geometry_shader4
GL_ARB_get_program_binary
GL_ARB_gpu_shader5
GL_ARB_gpu_shader_fp64
GL_ARB_half_float_pixel
GL_ARB_half_float_vertex
GL_ARB_instanced_arrays
GL_ARB_internalformat_query
GL_ARB_internalformat_query2
GL_ARB_map_buffer_alignment
GL_ARB_map_buffer_range
GL_ARB_multi_draw_indirect
GL_ARB_multisample
GL_ARB_multitexture
GL_ARB_occlusion_query
GL_ARB_occlusion_query2
GL_ARB_pixel_buffer_object
GL_ARB_point_parameters
GL_ARB_point_sprite
GL_ARB_program_interface_query
GL_ARB_provoking_vertex
GL_ARB_robustness
GL_ARB_sample_shading
GL_ARB_sampler_objects
GL_ARB_seamless_cube_map
GL_ARB_separate_shader_objects
GL_ARB_shader_atomic_counters
GL_ARB_shader_bit_encoding
GL_ARB_shader_objects
GL_ARB_shader_precision
GL_ARB_shader_subroutine
GL_ARB_shading_language_100
GL_ARB_shading_language_420pack
GL_ARB_shading_language_packing
GL_ARB_shadow
GL_ARB_stencil_texturing
GL_ARB_sync
GL_ARB_tessellation_shader
GL_ARB_texture_border_clamp
GL_ARB_texture_buffer_object_rgb32
GL_ARB_texture_buffer_range
GL_ARB_texture_compression
GL_ARB_texture_compression_bptc
GL_ARB_texture_compression_rgtc
GL_ARB_texture_cube_map
GL_ARB_texture_cube_map_array
GL_ARB_texture_env_add
GL_ARB_texture_env_combine
GL_ARB_texture_env_crossbar
GL_ARB_texture_env_dot3
GL_ARB_texture_float
GL_ARB_texture_gather
GL_ARB_texture_multisample
GL_ARB_texture_non_power_of_two
GL_ARB_texture_query_lod
GL_ARB_texture_rectangle
GL_ARB_texture_rg
GL_ARB_texture_rgb10_a2ui
GL_ARB_texture_storage
GL_ARB_texture_storage_multisample
GL_ARB_texture_swizzle
GL_ARB_timer_query
GL_ARB_transform_feedback2
GL_ARB_transform_feedback3
GL_ARB_transform_feedback_instanced
GL_ARB_transpose_matrix
GL_ARB_uniform_buffer_object
GL_ARB_vertex_array_bgra
GL_ARB_vertex_array_object
GL_ARB_vertex_attrib_64bit
GL_ARB_vertex_attrib_binding
GL_ARB_vertex_buffer_object
GL_ARB_vertex_program
GL_ARB_vertex_shader
GL_ARB_vertex_type_2_10_10_10_rev
GL_ARB_viewport_array
GL_ARB_window_pos
GL_ATI_separate_stencil
GL_EXT_abgr
GL_EXT_bgra
GL_EXT_blend_color
GL_EXT_blend_equation_separate
GL_EXT_blend_func_separate
GL_EXT_blend_minmax
GL_EXT_blend_subtract
GL_EXT_clip_volume_hint
GL_EXT_compiled_vertex_array
GL_EXT_draw_buffers2
GL_EXT_draw_range_elements
GL_EXT_fog_coord
GL_EXT_framebuffer_blit
GL_EXT_framebuffer_multisample
GL_EXT_framebuffer_object
GL_EXT_geometry_shader4
GL_EXT_gpu_program_parameters
GL_EXT_gpu_shader4
GL_EXT_multi_draw_arrays
GL_EXT_packed_depth_stencil
GL_EXT_packed_float
GL_EXT_packed_pixels
GL_EXT_rescale_normal
GL_EXT_secondary_color
GL_EXT_separate_specular_color
GL_EXT_shader_integer_mix
GL_EXT_shadow_funcs
GL_EXT_stencil_two_side
GL_EXT_stencil_wrap
GL_EXT_texture3D
GL_EXT_texture_array
GL_EXT_texture_buffer
GL_EXT_texture_compression_s3tc
GL_EXT_texture_edge_clamp
GL_EXT_texture_env_add
GL_EXT_texture_env_combine
GL_EXT_texture_filter_anisotropic
GL_EXT_texture_integer
GL_EXT_texture_lod_bias
GL_EXT_texture_rectangle
GL_EXT_texture_sRGB
GL_EXT_texture_sRGB_decode
GL_EXT_texture_shared_exponent
GL_EXT_texture_snorm
GL_EXT_texture_storage
GL_EXT_texture_swizzle
GL_EXT_transform_feedback
GL_IBM_texture_mirrored_repeat
GL_INTEL_map_texture
GL_INTEL_performance_queries
GL_INTEL_performance_query
GL_KHR_blend_equation_advanced
GL_KHR_debug
GL_NV_blend_square
GL_NV_conditional_render
GL_NV_primitive_restart
GL_NV_texgen_reflection
GL_SGIS_generate_mipmap
GL_SGIS_texture_edge_clamp
GL_SGIS_texture_lod
GL_SUN_multi_draw_arrays
GL_WIN_swap_hint
WGL_ARB_buffer_region
WGL_ARB_create_context
WGL_ARB_create_context_profile
WGL_ARB_create_context_robustness
WGL_ARB_extensions_string
WGL_ARB_framebuffer_sRGB
WGL_ARB_make_current_read
WGL_ARB_multisample
WGL_ARB_pbuffer
WGL_ARB_pixel_format
WGL_ARB_pixel_format_float
WGL_EXT_create_context_es2_profile
WGL_EXT_create_context_es_profile
WGL_EXT_depth_float
WGL_EXT_extensions_string
WGL_EXT_pixel_format_packed_float
WGL_EXT_swap_control
WGL_EXT_swap_control_tear
WGL_NV_DX_interop
Implementation Dependent OpenGL Limits:
Maximum DrawElements Vertices: 1048576
Maximum DrawElements Indices: 1048576
GLSL:
Maximum Varying Floats: 64
Maximum Vertex Attributes: 16
Maximum Vertex Uniform Components: 4096
Maximum Fragment Uniform Components: 4096
Maximum Vertex Image Units: 16
Maximum Fragment Image Units: 16
Maximum Pipeline Image Units: 96
Cycles:
CPU device capabilities: SSE2 SSE3 SSE41 AVX
OpenCL device capabilities:
Number of platforms: 1
Platform #0
Platform Name: Intel(R) OpenCL
Platform Vendor: Intel(R) Corporation
Platform Version: OpenCL 1.2
Platform Profile: FULL_PROFILE
Platform Extensions: cl_intel_dx9_media_sharing cl_khr_byte_addressable_store cl_khr_d3d11_sharing cl_khr_dx9_media_sharing cl_khr_gl_sharing cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_icd cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics
Number of devices: 2
		Device: #0
			Device Name:        Intel(R) Core(TM) i3-3120M CPU @ 2.50GHz
			Device Vendor: Intel(R) Corporation
			Device OpenCL C Version: OpenCL C 1.2
			Device Profile: FULL_PROFILE
			Device Version: OpenCL 1.2 (Build 76427)
			Device Extensions: cl_khr_fp64 cl_khr_icd cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_khr_byte_addressable_store cl_intel_printf cl_ext_device_fission cl_intel_exec_by_local_thread cl_khr_gl_sharing cl_intel_dx9_media_sharing cl_khr_dx9_media_sharing cl_khr_d3d11_sharing
			Device Max clock frequency (MHz): 2500
			Device Max compute units: 4
			Device Max work group size: 1024
		Device: #1
			Device Name: Intel(R) HD Graphics 4000
			Device Extensions: cl_intel_d3d11_nv12_media_sharing cl_intel_dx9_media_sharing cl_khr_3d_image_writes cl_khr_byte_addressable_store cl_khr_d3d10_sharing cl_khr_d3d11_sharing cl_khr_depth_images cl_khr_dx9_media_sharing cl_khr_gl_depth_images cl_khr_gl_event cl_khr_gl_msaa_sharing cl_khr_gl_sharing cl_khr_global_int32_base_atomics cl_khr_global_int32_extended_atomics cl_khr_icd cl_khr_image2d_from_buffer cl_khr_local_int32_base_atomics cl_khr_local_int32_extended_atomics cl_intel_accelerator cl_intel_motion_estimation
			Device Max clock frequency (MHz): 1100
			Device Max compute units: 16
			Device Max work group size: 512
Enabled add-ons:
io_scene_fbx (version: (4, 14, 4), path: E:\BLENDER\BLENDER-VESRSIONS\blender-2.80\2.80\scripts\addons\io_scene_fbx\init__.py)
io_anim_bvh (version: (1, 0, 0), path: E:\BLENDER\BLENDER-VESRSIONS\blender-2.80\2.80\scripts\addons\io_anim_bvh\
init.py)
io_mesh_ply (version: (1, 0, 0), path: E:\BLENDER\BLENDER-VESRSIONS\blender-2.80\2.80\scripts\addons\io_mesh_ply\
init.py)
io_scene_obj (version: (3, 5, 6), path: E:\BLENDER\BLENDER-VESRSIONS\blender-2.80\2.80\scripts\addons\io_scene_obj\
init.py)
io_scene_x3d (version: (2, 2, 1), path: E:\BLENDER\BLENDER-VESRSIONS\blender-2.80\2.80\scripts\addons\io_scene_x3d\
init.py)
io_mesh_stl (version: (1, 1, 3), path: E:\BLENDER\BLENDER-VESRSIONS\blender-2.80\2.80\scripts\addons\io_mesh_stl\
init.py)
io_mesh_uv_layout (version: (1, 1, 1), path: E:\BLENDER\BLENDER-VESRSIONS\blender-2.80\2.80\scripts\addons\io_mesh_uv_layout\
init.py)
io_curve_svg (version: UNKNOWN, path: E:\BLENDER\BLENDER-VESRSIONS\blender-2.80\2.80\scripts\addons\io_curve_svg\
init.py)
cycles (version: UNKNOWN, path: E:\BLENDER\BLENDER-VESRSIONS\blender-2.80\2.80\scripts\addons\cycles\
init.py)
io_scene_gltf2 (version: (0, 0, 1), path: E:\BLENDER\BLENDER-VESRSIONS\blender-2.80\2.80\scripts\addons\io_scene_gltf2\
init__.py)
Right, the problem with this specific GPU has been reported before, that's why it was merged into the other report.
I tried blender2.8 on linux ubunto, it work better and dont crush (: , i hope to fix it on windows , i now my laptop and GPU is very old but i dont have money to by a new one ): because i am student ,and thanks for your help.
