Select co-planar faces fails #62595
Reference: blender/blender#62595
With the attached blend file select co-planar faces, notice faces pointing in the opposite direction on a different plane are also selected.
coplanarfails.blend
Added subscriber: @ideasman42
#61799 was marked as duplicate of this issue
Checked the method this is using and not sure we can reliably encode a plane as v3 float into a kd-tree in a way that also keeps distance measurements valid.
This could be solved by a kd-tree that has an arbitrary number of dimensions and takes a custom distance callback when finding nearest since we want to compare the normal w/ a different epsilon to the distance.
Added subscriber: @HerbertPohlai
I'll try to fix this.
Hmm, I tried one other approach, but also does not seems to work.
I guess just having a 4D kdtree could fix this problem. Then the plane could be converted in
Ax + By + Cz = D
form and thennormalized(A, B, C, D)
can be stored in the kd tree.Or we just use the trivial quadratic algorithm to find coplanar faces.
This issue was referenced by
3b9b324bf6
