Dynamic Paint #62600
5 Participants
Reference: blender/blender#62600
Dynamic Paint
Hi look the problem with Dynamic Paint in a blender has not been solved . Although I'm still 2 February about this problem said ... blender file attached
wrong.blend
suse 15.0
GeForce Gtx 260
blender-2.80-a38205fbd801-linux-glibc224-x86_64
p.s Well, it's not essential -just a little annoying color in the program itself, return as in version 2.79
Added subscriber: @Tao-2
Added subscriber: @StephenSwaney
What exactly is the problem?
The problem is that it doesn't work !!! when trying to create this type of video https://www.youtube.com/watch?v=jpWoNtc5QU0 .the video's not mine if anything .
to Brecht Van Lommel Dynamic Paint
wave
In the file that I applied all the settings for this problem are present, as well as data for the operating system and computer hardware.Added subscriber: @ZedDB
With the latest blender beta, the cube seems to be deformed but the sphere on impact. Has the issue been solved?
the problem is not solvedin the morning downloaded version blender-2.80-b936d7b16c62-linux-glibc224-x86_64,But there is a progress cube began to be squeezed ,under the sphere but the wave effect on the cube no...p.s
I however found one more problem the command ctrl f12
does not perform rendering at all ,and collapses the program BUT at a mouse click in the menu of the program works ...I get the same result with 2.79 as with 2.8
rec_27.mp4
recording.mp4
You are saying you do not get this result?
Yes
The you will have to provide some more information on this as "it doesn't work" is not enough information.
suse 15.0
GeForce Gtx 260
kde 5.12.6
qt 5.9.4
kernel 4.12.14 Ip150.12.48 default
4amd Phenom(tm)x4 945
4.8g mem
GeForce Gtx 260 pcie/sse2
3.3.0 NVIDIA 340.107
WDC WD5000AAKX-001CA0
SAMSUNG HD753LJ
what other information do you need ? how do I do it or what parameters do I enter ? the parameters of the default cube subdivided forgot , if what you mean that is not able to handle the program,not the first day working with this program ...
in version 2.79 everything works perfectly...
p.s Well, for a tough ending,climb into 2.8 and see if the video editor works ?
Added subscriber: @YAFU
From your file manager, you enter "/home/YOUR_USERNAME/.config/blender" folder (~/.config/blender). You rename there "2.80" folder, for example to "2.80-original". You try again downloading last linux build from:
https://builder.blender.org/download/
If the problem persists, you try to show a video of the problem you have.
Friend your advice did not help ,the result is what I want worked a little before lecturing Sebastian Parborg. my version is blender-2.80-b936d7b16c62-linux-glibc224-x86_64 on March 31... downloaded this morning ... along the way, even tried to delete the folder with the 2.8 config.
As pointed out by YAFU, showing us how it fails would be a good start.
You can also attach the output of blender if you run with the the
--debug
flag while trying to playback the animation.Added subscriber: @mont29
