2.80,There is something wrong with User perspective in 3D view.
Closed, InvalidPublic
1.If you rotate the view from top/right/front orthographic, it will switch to perspective without command.
2.If the object's size is too small, perspective will wrong.
Thanks for all your help.
Sebastian Koenig (sebastian_k) closed this task as Invalid.
These are both no bugs.
The first one is the effect of the setting "Auto Perspective" in Preferences > Navigation > Orbit & Pan.
The second one is the effect of "Clip Start" value being too high in your case. Go to the View Panel in 3D Viewport Sidebar ("N") and set Clip Start to 0.001 instead of 0.1. Then your cube will be visible even when you are zoomed in that far as in your case.
