Multi-object-Mode: EditMode transform properties
Confirmed, LowPublicTO DO
Edit-mode buttons currently only show median values for the active edit-object.
The Mean Crease value of the N panel doesn't work for multiple objects:
Here i have 2 objects selected
In Edit Mode changing the Mean Crease value does change its effect only on the selected object:
William Reynish (billreynish) lowered the priority of this task from 90 to Low.
That's an interesting topic of discussion. This is not exclusive to creases, the same is valid for Transform for instance.
I would say the bug is that Alt+Edit a property in the UI is not working for edit mode, only object mode settings. Maybe in this case it should work without [alt] being required though. Not sure.
@Campbell Barton (campbellbarton) what do you say? TODO or bug?
This could be supported w/o Alt+Edit, just as operators don't a different way to access editing multiple edit objects at once (from the user perspective).
Campbell Barton (campbellbarton) renamed this task from Mean Crease for multiple objects to Multi-object-Mode: EditMode transform UI.Mar 20 2019, 6:00 AM
Campbell Barton (campbellbarton) renamed this task from Multi-object-Mode: EditMode transform UI to Multi-object-Mode: EditMode transform properties.
Campbell Barton (campbellbarton) updated the task description. (Show Details)
Campbell Barton (campbellbarton) edited a custom field.
The median value showed is for all objects iirc (not in my computer now). Bur editing only affects the active.
Edit: Nevermind, it indeed only shows for the active.
