Principled BSDF base color alpha value is not reflected in viewport with alpha blend #62794
Closed
opened 2019-03-20 23:27:54 +01:00 by Dan Sinni · 18 comments
Graphics card: GeForce GTX 860M/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 398.36
Broken: version: 2.80 (sub 51), branch: master, commit date: 2019-03-20 16:33, hash: b6d1946c2e
When using the Principled BSDF shader with a Base Color Alpha value less than 1.0, in conjunction with setting the material's Blend Mode to Alpha Blend, the Alpha value is not reflected in the viewport. It seems to display at a fixed semi-transparent value, regardless of what is set.
The Alpha is set to 0.010, which is almost wholly transparent:
This is what shows in viewport:
Note that the cube shows at approximately 0.5 alpha (gauged by eye), regardless of set value, and that the plane is not at all visible through the cube.
As it is now, this is the workflow for exporting transparency to glTF, so I believe it to be considerably important to be able to preview the transparency based on its value before exporting.
  • Add a cube or any mesh
  • Add default material using Principled BSDF shader
  • Set Base Color and set Alpha to less than 1.0
  • Set material's Blend Mode to Alpha Blend
  • Adjust Base Color Alpha value and see no adjustments in viewport
Blend file
AlphaBlendIssue.blend
**System Information** Operating system: Windows-10-10.0.17134 64 Bits Graphics card: GeForce GTX 860M/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 398.36 **Blender Version** Broken: version: 2.80 (sub 51), branch: master, commit date: 2019-03-20 16:33, hash: `b6d1946c2e` Worked: (optional) **Short description of error** When using the `Principled BSDF` shader with a `Base Color` `Alpha` value less than `1.0`, in conjunction with setting the material's `Blend Mode` to `Alpha Blend`, the `Alpha` value is not reflected in the viewport. It seems to display at a fixed semi-transparent value, regardless of what is set. The `Alpha` is set to `0.010`, which is almost wholly transparent: ![image.png](https://archive.blender.org/developer/F6857613/image.png) This is what shows in viewport: ![image.png](https://archive.blender.org/developer/F6857617/image.png) Note that the cube shows at approximately `0.5` alpha (gauged by eye), regardless of set value, and that the plane is not at all visible through the cube. As it is now, this is the workflow for exporting transparency to `glTF`, so I believe it to be considerably important to be able to preview the transparency based on its value before exporting. **Exact steps for others to reproduce the error** - Add a cube or any mesh - Add default material using `Principled BSDF` shader - Set `Base Color` and set `Alpha` to less than `1.0` - Set material's `Blend Mode` to `Alpha Blend` - Adjust `Base Color` `Alpha` value and see no adjustments in viewport **Blend file** [AlphaBlendIssue.blend](https://archive.blender.org/developer/F6857665/AlphaBlendIssue.blend)
Author
Added subscriber: @DanSinni
#67327 was marked as duplicate of this issue
#58281 was marked as duplicate of this issue
Added subscribers: @Ajkad, @brecht
Color sockets in Cycles and Eevee do not actually have an alpha value, this is a leftover from old Blender Internal code. This needs to be cleaned up in the UI still. For transparency you should mix with the Transparent BSDF.
Brecht Van Lommel changed title from `Principled BSDF` shader `Base Color` `Alpha` value is not reflected in viewport with `Alpha Blend` to Principled BSDF base color alpha value is not reflected in viewport with alpha blend 2019-03-20 23:38:41 +01:00
Author
Appreciate the feedback, Brecht. However, I don't believe the glTF exporter currently supports the Transparent BSDF shader; it relies on Alpha from either the Base Color or from a texture linked through the Base Color node of the Principled BSDF, Background, and possibly Emission shaders.
Note that the Alpha value does work as expected when linked through something like the Background shader (which is currently used to export unlit materials in glTF) or the Emission shader:
Appreciate the feedback, Brecht. However, I don't believe the glTF exporter currently supports the Transparent BSDF shader; it relies on Alpha from either the Base Color or from a texture linked through the Base Color node of the Principled BSDF, Background, and possibly Emission shaders. Note that the Alpha value *does* work as expected when linked through something like the Background shader (which is currently used to export unlit materials in glTF) or the Emission shader: ![image.png](https://archive.blender.org/developer/F6857811/image.png) ![image.png](https://archive.blender.org/developer/F6857816/image.png)
Added subscriber: @donmccurdy
Thanks Brecht – you mentioned earlier that you'd like to add opacity to the Principled BSDF node. I realize opacity and alpha are not the same thing, so just to clarify – do you still think there should eventually be an opacity socket on the Principled node? Or is mixing with the Transparent BSDF likely to be the long-term answer?
The glTF exporter can be made to support either one, but we'd like to have a future-proof way of representing opacity that feels natural in Blender, so we don't train our users to do something that's going to break in the near future. I misunderstood your earlier comment about opacity as meaning that you wanted to support an alpha channel on the basecolor socket, which is why the exporter is requiring that now, and if it's just a UI glitch that is going away then we should change that in the exporter. In general mixed nodes are hard for us to export reliably, part of the reason for our excitement about Principled BSDF, but I suppose an exception could be made for Transparent BSDF here.
Thanks Brecht – you [mentioned earlier](https://devtalk.blender.org/t/alpha-opacity-displacement-parallax-and-ao-input-for-the-principled-shader/3096/5?u=donmccurdy) that you'd like to add opacity to the Principled BSDF node. I realize opacity and alpha are not the same thing, so just to clarify – do you still think there should eventually be an opacity socket on the Principled node? Or is mixing with the Transparent BSDF likely to be the long-term answer? The glTF exporter can be made to support either one, but we'd like to have a future-proof way of representing opacity that feels natural in Blender, so we don't train our users to do something that's going to break in the near future. I misunderstood your earlier comment about opacity as meaning that you wanted to support an alpha channel on the basecolor socket, which is why the exporter is requiring that now, and if it's just a UI glitch that is going away then we should change that in the exporter. In general mixed nodes are hard for us to export reliably, part of the reason for our excitement about Principled BSDF, but I suppose an exception could be made for Transparent BSDF here.
Member
Added subscriber: @elm19087
Added subscriber: @christian
This comment was removed by @christian
*This comment was removed by @christian*
Added subscriber: @GaiaClary
Added subscriber: @fclem
Clément Foucault self-assigned this 2020-01-17 20:21:36 +01:00
Alpha handling is now consistent with cycles due to the blend mode refactor done for 2.81.
I don't know about the glTF addon but I would expect that since the time, they would have fixed it.
Alpha handling is now consistent with cycles due to the blend mode refactor done for 2.81. I don't know about the glTF addon but I would expect that since the time, they would have fixed it.
The glTF addon uses the new 'alpha' socket on the Principled BSDF node, which works correctly in the viewport too. So yes, I think this is resolved. Thanks!
Member
Is the Alpha value of the Base color in the Principled BSDF Shader still used anywhere?
The alpha values of the base color (or any color socket in shading nodes) should not be used.
We still have to remove it from the user interface.
The alpha values of the base color (or any color socket in shading nodes) should not be used. We still have to remove it from the user interface.
8 Participants
Reference: blender/blender#62794
