Grease pencil extrude generates broken vertex weights #62872
7 Participants
Reference: blender/blender#62872
Operating system: Ubuntu 18.04
Graphics card: Radeon RX 580 Series
Blender 2.80 (sub 51), Commit date: 2019-03-22 21:47, Hash
faecac0b5e
Blender 2.80 (sub 51), Commit date: 2019-03-21 23:13, Hash
1ae6aaad43
Both recent versions have this bug
Blender sometimes crashes while pressing ctrl+z after any action. Hard to tell exact steps to reproduce bug. In my most recent cases it crashed 1) after I pressed ctrl+z after drawing a grease pencil stroke, 2) after I selected some objects and bones and pressed ctrl+z.
Here are --debug-gpu logs for two recent releases of blender 2.8 and console output
test.crash.txt
test2.crash.txt
bl debug log
Added subscriber: @AnnaIv
Added subscriber: @matc
Does
./blender --debug-gpu
always crash for you? What kernel version are you currently using? (uname -a
)Yes, it always crashes in debug-gpu mode. I mean, it may work okay for some time, but after I do some action (not some particular action, as I can see) and press ctrl+z it may crash blender.
**My kernel version is:**Linux 4.15.0-46-generic #49-Ubuntu SMP Wed Feb 6 09:33:07 UTC 2019 x86_64 x86_64 x86_64 GNU/Linux
I was drawing my character and managed to make extremely crashy blender file.
How to reproduce crash:
test crash.blend
Added subscriber: @ZedDB
I think that you might need newer GPU drivers. The ones that come with 18.04 per default is ancient by now.
What is the output of
glxinfo | grep OpenGL
?Added subscriber: @Sergey
Actually, nevermind I can reproduce this crash on my end too.
If I open that file and select the character and go into GP draw mode, draw 10 strokes or so and then undo a bunch I get the following segfault:
@Sergey is this for you? It seem to be DEG stuff.
Currently I'm using proprietary AMD Radeon drivers "amdgpu-pro-18.40-676022-ubuntu-18.04"
I'm also on AMD Ryzen 2600x processor.
It takes me drawing one grease pencil stroke to instantly crash this file after pressing ctrl+z
My error does not appear to be related to DEG. I had to draw two strokes and hit undo twice to trigger the crash. (Fedora with 4.20.16 kernel). I was not able to trigger the crash on windows 10 .
Added subscriber: @intrigus-3
Added subscriber: @antoniov
This goes deeper into grease pencil code, which does not handle vertex groups weights correctly in some cases.
For example, extrude operator leaves two stroke points which points to the same weights array.
@antoniov, there is missing duplication of
dw
ingpencil_add_move_points()
. Simply open the file from below, extrude, save and reload and see heap-use-after-free indirect_link_dverts()
.gpencil_stroke_extrude.blend
P.S. Not sure we can easily fix existing files, so attaching a corrected one which should have all pointers assigned correctly.test crash fixed.blend
@Sergey Thanks for the info, I think I can fix it.
With this change it's possible to work with the original file. There are 10 blocks ("Data from GD") remaining, that are not freed until the file has been saved once.
Edit: I did a quick test on windows 10. The patch removes the
Couldn't unmap memory
errors when opening the file. The 10 blocks remain unfreed, until once saved and blender reopened.Added subscriber: @brecht
With the extrude bug fixed I think we can close this issue.
Blender 2.8 "ctrl+z" crashes, segmentation faultto Grease pencil extrude generates broken vertex weights
