particle hair combing issue 2.8 and 2.79 #62877
Reference: blender/blender#62877
Operating system: win 10 latest
Graphics card: gtx 1070
Broken: blender-2.80-faecac0b5e14-win64
Worked: no idea
combing particle hair is glitching under some circumstances i think issue is similar to this: https://developer.blender.org/T61226
normal uv sphere seems to work fine for combing, but if you take for example apply shinkwrap modifier on a uv sphere to make a scalp mesh from human head, this scalp will have glitched behavior when adding hair to it and trying to comb it
the issue behaves in same manner on 2.79 as well
combing-issue.blend
Added subscriber: @dev369
Added subscribers: @JacquesLucke, @ZedDB
@JacquesLucke any idea what is going on here? The hair seem to clump together and jiggle back and forth.
The root cause of the issue are degenerate faces (the area of some triangles is 0).
Those were probably generated by the Shrinkwrap modifier.
This leads to bad normals (see image below, which only shows a part of the mesh in the file).
In particle edit mode, the option Deflect Emitter was activated in the topbar.
This option is supposed to prevent hair-mesh intersections.
To do this, it uses the normals, to decide which hair points have to be adjusted.
Since the normals are incorrect, this does not work.
There are two possible solutions:
Deflect Emitter
.The second solution should be preferred, because degenerate faces will most probably generate other problems later in the project.
