DAE Export Issue -- matrix transforms
Confirmed, NormalPublicKNOWN ISSUE
Operating system: macOS 10.14.3
Graphics card: NVIDIA GeForce GT 650M 1024 MB, Intel HD Graphics 4000 1536 MB
Broken: (example: 2.80, fa59c6a3e7d7, master, 2019-03-19, as found on the splash screen)
When exporting an animation in collada .dae format, I have set the the transforms to be matrix. But there are some cases in nodes, where rotation, scale and translate are still present. Should it *all* be a matrix per export setting?
For instance, the node Cylinder still has translate, rotate and scale. But I would expect this should be consolidated into a matrix but it is not. In the export settings, the transform type was set to Matrix not "TransLocRot". Should that be "TransRotScale"? You can see the Camera and Light nodes are matrix but not the cylinder node. So, it appears the file export is inconsistent.
<node id="Cylinder" name="Cylinder" type="NODE">
         <translate sid="location">0 0 0</translate>
         <rotate sid="rotationZ">0 0 1 0</rotate>
         <rotate sid="rotationY">0 1 0 0</rotate>
         <rotate sid="rotationX">1 0 0 0</rotate>
         <scale sid="scale">1 1 1</scale>
         <instance_controller url="#Armature_Cylinder-skin">
           <skeleton>#Armature_Bone</skeleton>
           <bind_material>
             <technique_common>
               <instance_material symbol="Material-material" target="#Material-material">
                 <bind_vertex_input semantic="UVMap" input_semantic="TEXCOORD" input_set="0"/>
               </instance_material>
             </technique_common>
           </bind_material>
         </instance_controller>
       </node>
     </node>
     <node id="Camera" name="Camera" type="NODE">
       <matrix sid="transform">0.6859207 -0.3240135 0.6515582 7.358891 0.7276763 0.3054208 -0.6141704 -6.925791 0 0.8953956 0.4452714 4.958309 0 0 0 1</matrix>
       <instance_camera url="#Camera-camera"/>
     </node>
     <node id="Light" name="Light" type="NODE">
       <matrix sid="transform">-0.2908646 -0.7711008 0.5663932 4.076245 0.9551712 -0.1998834 0.2183912 1.005454 -0.05518906 0.6045247 0.7946723 5.903862 0 0 0 1</matrix>
       <instance_light url="#Light-light"/>
     </node>
Export a file in .dae Collada format. "Includes animations" should be checked and "Samples" button selected. Make sure under the Anim tab that "Transformation Type" is set to "Matrix".
The exported file is attached. Nothing spectacular.
Sebastian Parborg (zeddb) lowered the priority of this task from 90 to Normal.Mar 25 2019, 2:19 PM
There is another bug related to this. If you set the export settings to enable translate, scale and rotate ( the TransLocRot option ), then it produces them only for node type="NODE". Otherwise, for node type="JOINT", the export still creates a matrix. Just feedback.
Bastien Montagne (mont29) changed the subtype of this task from "Report" to "Known Issue".Feb 13 2020, 9:26 PM
Bastien Montagne (mont29) edited projects, added Import/Export; removed Tracker Curfew.
