Wireframe input node not working in Eevee anymore
I'm attaching a Blend file. So I just compiled Blender, March 25th and if you connect a wireframe node in Eevee, the result of the shader is pink. So in the attached example, instead of looking like this:
it's looks totally pink
Clément Foucault (fclem) triaged this task as Needs Information from User priority.Mar 25 2019, 6:59 PM
It works here (Linux + AMD Vega). What is your system spec? Also give us the output of blender running in a terminal with the options --debug.
Hi Clément!
I'm attaching the console output. System is Kubuntu 18.04, geforce 1080, driver 415.27
I have a another build compiled a couple of days ago and it works perfectly well there.
