Graphics card: GeForce GTX 1070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 418.81
Broken: version: 2.80 (sub 51), branch: blender2.7, commit date: 2019-03-25 23:15, hash: rBadfdae3fc2f4
Just click once sometimes work right
This bug happen in both 2.79 and 2.8
Click and drag the hair cut tool mess up the vertices position, especially after subdividing one or 2 segments of the hair. After the hair is messed up, it can't be fixed using rekey command.
Dragging the cut tool on a hair that is not subdivided also cause the problem, but not as severely, the vertices become unevenly positioned.
Create a hair system on the default cube, set the emission number to 1.
Go to particle edit mode, subdivide one or 2 segments of the hair.
Use the cut tool, click and drag from the tip of the hair.
The hair is now completely messed up.
