Outliner crash when selecting object being in armature editmode [modeswitch] #63066
Closed
opened 2019-03-28 23:42:37 +01:00 by Cliff King · 11 comments
{F6896675}System Information
Graphics card: GeForce GTX 1070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 419.67
Broken: version: 2.80 (sub 52), branch: master, commit date: 2019-03-28 21:08, hash: 42dd888b98
Blender 2.8 beta abruptly shuts down (ie. crashes) if you open attached model and click on pencil-mesh in Outliner!
{[F6896675](https://archive.blender.org/developer/F6896675/pencil-mesh.blend)}**System Information** Operating system: Windows-10-10.0.17134 64 Bits Graphics card: GeForce GTX 1070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 419.67 **Blender Version** Broken: version: 2.80 (sub 52), branch: master, commit date: 2019-03-28 21:08, hash: `42dd888b98` Worked: (optional) **Short description of error** Blender 2.8 beta abruptly shuts down (ie. crashes) if you open attached model and click on pencil-mesh in Outliner!
Author
Added subscriber: @Bartwynn
Member
Added subscriber: @lichtwerk
Member
Confirmed, checking...
Member
Happens when you are in armature editmode (not in posemode) and click on another object (not object data).
This will switch to objectmode (thus editbones are not valid anymore).
  • works fine if you are in posemode [and switch to objectmode from there]
  • works fine if you are in editmode and select the pencil mesh datablock [still in editmode then]
got a bandaid fix (since in this case we can check for obedit later):
P944: T63066_snippet
diff --git a/source/blender/editors/space_outliner/outliner_select.c b/source/blender/editors/space_outliner/outliner_select.c
index 5ace2c291e0..faca9668db3 100644
--- a/source/blender/editors/space_outliner/outliner_select.c
+++ b/source/blender/editors/space_outliner/outliner_select.c
@@ -691,13 +691,16 @@ static void tree_element_active_ebone__sel(bContext *C, Object *obedit, bArmatur
 static eOLDrawState tree_element_active_ebone(
         bContext *C, TreeElement *te, TreeStoreElem *UNUSED(tselem), const eOLSetState set, bool recursive)
-	Object *obedit = CTX_data_edit_object(C);
-	BLI_assert(obedit != NULL);
-	bArmature *arm = obedit->data;
 	EditBone *ebone = te->directdata;
 	eOLDrawState status = OL_DRAWSEL_NONE;
 	if (set != OL_SETSEL_NONE) {
+		/* obedit can be NULL if we just selected another object
+		 * (thus having switched to objecmode) */
+		Object *obedit = CTX_data_edit_object(C);
+		BLI_assert(obedit != NULL);
+		bArmature *arm = obedit->data;
 		if (set == OL_SETSEL_NORMAL) {
 			if (!(ebone->flag & BONE_HIDDEN_A)) {
 				ED_armature_edit_deselect_all(obedit);
But there are other glitches as well (after selecting the Pencil):
  • Armature goes completely invisible [will have to check why that is]
  • Bone still draws as active (with a circle around the icon) which should only be the the case if the Armature is really
Will check the two "works fine" cases mentioned above (and will also check if we rebuild the tree on mode changes...)
Happens when you are in armature editmode (not in posemode) and click on another object (not object data). This will switch to objectmode (thus editbones are not valid anymore). - works fine if you are in posemode [and switch to objectmode from there] - works fine if you are in editmode and select the pencil mesh datablock [still in editmode then] got a bandaid fix (since in this case we can check for obedit later): [P944: T63066_snippet](https://archive.blender.org/developer/P944.txt) ``` diff --git a/source/blender/editors/space_outliner/outliner_select.c b/source/blender/editors/space_outliner/outliner_select.c index 5ace2c291e0..faca9668db3 100644 --- a/source/blender/editors/space_outliner/outliner_select.c +++ b/source/blender/editors/space_outliner/outliner_select.c @@ -691,13 +691,16 @@ static void tree_element_active_ebone__sel(bContext *C, Object *obedit, bArmatur static eOLDrawState tree_element_active_ebone( bContext *C, TreeElement *te, TreeStoreElem *UNUSED(tselem), const eOLSetState set, bool recursive) { - Object *obedit = CTX_data_edit_object(C); - BLI_assert(obedit != NULL); - bArmature *arm = obedit->data; EditBone *ebone = te->directdata; eOLDrawState status = OL_DRAWSEL_NONE; if (set != OL_SETSEL_NONE) { + /* obedit can be NULL if we just selected another object + * (thus having switched to objecmode) */ + Object *obedit = CTX_data_edit_object(C); + BLI_assert(obedit != NULL); + bArmature *arm = obedit->data; + if (set == OL_SETSEL_NORMAL) { if (!(ebone->flag & BONE_HIDDEN_A)) { ED_armature_edit_deselect_all(obedit); ``` But there are other glitches as well (after selecting the Pencil): - Armature goes completely invisible [will have to check why that is] - Bone still draws as active (with a circle around the icon) which should only be the the case if the Armature is really Will check the two "works fine" cases mentioned above (and will also check if we rebuild the tree on mode changes...)
Philipp Oeser changed title from Blender 2.8 Beta Crashes to Outliner crash when selecting object being in armature editmode [modeswitch] 2019-03-29 11:38:38 +01:00
Member
Hm, just found out about a01244cade, #55246 (needs another round of thinking...)
Campbell Barton was assigned by Philipp Oeser 2019-03-29 15:04:27 +01:00
Member
Added subscriber: @ideasman42
Member
Still confused actually.
There is also the case where tree_element_active_ebone (where the above assert happens) acts up in case of multi-armature select.
It just feels weird to use CTX_data_edit_object(C) here?
This will give us the active edit object, but in the file below this will be the same armature for all three selected armatures [which are all different].
This will lead to erratic selection behaviour, see:
#63066.blend
try slecting different bones in different armatures from the outliner here, only the active ["03"] armature will select/deselect correctly, if you are selecting bones in "01" or "02" selection will act up [bones not being deselected etc]
I had another go at this and tried to not rely on CTX_data_edit_object(C), but instead use the armature directly from tselem... getting the corresponding object is a bit weak, but...
This will prevent mentioned crash and also improves upon selection from the outliner (I've also made sure all bones from other armatures are deselected, matching selection in 3dview...)
P945: T63066_snippet_2
index 5ace2c291e0..0fb2a3f9f87 100644
@@ -23,6 +23,8 @@
 #include <stdlib.h>
+#include "MEM_guardedalloc.h"
 #include "DNA_armature_types.h"
 #include "DNA_collection_types.h"
 #include "DNA_light_types.h"
@@ -689,18 +691,36 @@ static void tree_element_active_ebone__sel(bContext *C, Object *obedit, bArmatur
 	WM_event_add_notifier(C, NC_OBJECT | ND_BONE_ACTIVE, obedit);
-        bContext *C, TreeElement *te, TreeStoreElem *UNUSED(tselem), const eOLSetState set, bool recursive)
+        bContext *C, TreeElement *te, TreeStoreElem *tselem, const eOLSetState set, bool recursive)
+	bArmature *arm = (bArmature *)tselem->id;
+	ViewLayer *view_layer = CTX_data_view_layer(C);
+	View3D *v3d = CTX_wm_view3d(C);
+	uint objects_len = 0;
+	Object **objects = BKE_view_layer_array_from_objects_in_edit_mode_unique_data(view_layer, v3d, &objects_len);
+	Object *obedit = NULL;
+	for (uint ob_index = 0; ob_index < objects_len; ob_index++) {
+		obedit = objects[ob_index];
+		if (obedit->data == arm) {
+			break;
+	MEM_freeN(objects);
+	if (obedit == NULL) {
+		printf("warning, still no obedit...\n");
-				ED_armature_edit_deselect_all(obedit);
+				uint bases_len = 0;
+				Base **bases = BKE_view_layer_array_from_bases_in_edit_mode_unique_data(view_layer, v3d, &bases_len);
+				ED_armature_edit_deselect_all_multi_ex(bases, bases_len);
+				MEM_freeN(bases);
 				tree_element_active_ebone__sel(C, obedit, arm, ebone, true);
 				status = OL_DRAWSEL_NORMAL;
I think this one is actually for @ideasman42 to check on?
Still confused actually. There is also the case where `tree_element_active_ebone` (where the above assert happens) acts up in case of multi-armature select. It just feels weird to use CTX_data_edit_object(C) here? This will give us the active edit object, but in the file below this will be the same armature for all three selected armatures [which are all different]. This will lead to erratic selection behaviour, see: [#63066.blend](https://archive.blender.org/developer/F6898537/T63066.blend) try slecting different bones in different armatures from the outliner here, only the active ["03"] armature will select/deselect correctly, if you are selecting bones in "01" or "02" selection will act up [bones not being deselected etc] I had another go at this and tried to not rely on CTX_data_edit_object(C), but instead use the armature directly from tselem... getting the corresponding object is a bit weak, but... This will prevent mentioned crash and also improves upon selection from the outliner (I've also made sure all bones from other armatures are deselected, matching selection in 3dview...) [P945: T63066_snippet_2](https://archive.blender.org/developer/P945.txt) ``` diff --git a/source/blender/editors/space_outliner/outliner_select.c b/source/blender/editors/space_outliner/outliner_select.c index 5ace2c291e0..0fb2a3f9f87 100644 --- a/source/blender/editors/space_outliner/outliner_select.c +++ b/source/blender/editors/space_outliner/outliner_select.c @@ -23,6 +23,8 @@ #include <stdlib.h> +#include "MEM_guardedalloc.h" + #include "DNA_armature_types.h" #include "DNA_collection_types.h" #include "DNA_light_types.h" @@ -689,18 +691,36 @@ static void tree_element_active_ebone__sel(bContext *C, Object *obedit, bArmatur WM_event_add_notifier(C, NC_OBJECT | ND_BONE_ACTIVE, obedit); } static eOLDrawState tree_element_active_ebone( - bContext *C, TreeElement *te, TreeStoreElem *UNUSED(tselem), const eOLSetState set, bool recursive) + bContext *C, TreeElement *te, TreeStoreElem *tselem, const eOLSetState set, bool recursive) { - Object *obedit = CTX_data_edit_object(C); - BLI_assert(obedit != NULL); - bArmature *arm = obedit->data; + bArmature *arm = (bArmature *)tselem->id; + ViewLayer *view_layer = CTX_data_view_layer(C); + View3D *v3d = CTX_wm_view3d(C); + uint objects_len = 0; + Object **objects = BKE_view_layer_array_from_objects_in_edit_mode_unique_data(view_layer, v3d, &objects_len); + Object *obedit = NULL; + for (uint ob_index = 0; ob_index < objects_len; ob_index++) { + obedit = objects[ob_index]; + if (obedit->data == arm) { + break; + } + } + MEM_freeN(objects); + if (obedit == NULL) { + printf("warning, still no obedit...\n"); + }; + EditBone *ebone = te->directdata; eOLDrawState status = OL_DRAWSEL_NONE; if (set != OL_SETSEL_NONE) { if (set == OL_SETSEL_NORMAL) { if (!(ebone->flag & BONE_HIDDEN_A)) { - ED_armature_edit_deselect_all(obedit); + uint bases_len = 0; + Base **bases = BKE_view_layer_array_from_bases_in_edit_mode_unique_data(view_layer, v3d, &bases_len); + ED_armature_edit_deselect_all_multi_ex(bases, bases_len); + MEM_freeN(bases); + tree_element_active_ebone__sel(C, obedit, arm, ebone, true); status = OL_DRAWSEL_NORMAL; } ``` I think this one is actually for @ideasman42 to check on?
Added subscriber: @dfelinto
Campbell Barton was unassigned by Dalai Felinto 2019-04-09 14:56:59 +02:00
Dalai Felinto self-assigned this 2019-04-09 14:56:59 +02:00
I fixed related issues, let's me take a look.
This issue was referenced by e6151bc4c1
This issue was referenced by e6151bc4c1f218d506ecc4b577d77e1f86955277
Reference: blender/blender#63066
