Closing Console Quits Entire Program
Operating system: Windows 10
Graphics card: GE Force GTX 1050
Broken: 2.79
After toggling the console on, if you exit the console window by clicking the "X" it quits the entire program, losing all of your work.
This is definitely a bug and not a feature, both simple and serious enough to fix. I get that blender is a console program, but you should have access to the readout in a separate rendered window that is safe to close.
Toggle console on. Click "x" to close the window
Brecht Van Lommel (brecht) closed this task as Archived.
Not considered a bug currently. It's not at all simple to fix, basically the solution would be to eliminate the Windows console and implement one inside Blender itself.
This is just a Windows thing, right? Just removing the "close" button would eliminate all issues with it.
I think you just need to get the handle to the console window:
https://support.microsoft.com/en-ca/help/124103/how-to-obtain-a-console-window-handle-hwnd
Use that to get the menu on it...
HMENU hMenu = GetSystemMenu ( hwndConsole, FALSE);
Then delete the close button from the menu
DeleteMenu ( hMenu, 6, MF_BYPOSITION); // 'Close'
I like that idea a lot.
Never understood why that window exists outside of blender.
