self-baking normal map problem
Operating system: win 7
Graphics card: GTX 1050
Broken: 2.8 (05.04.2019)
Worked: 2.79.6 and 2.8 before 2019
Self-baking ignore custom normal data as auto smooth, normals baking like i bake it on smoothed mesh without smooth groups.
  1. create new docunent
  2. add any object with UV
  3. create new image from image editor
  4. add new material to mesh
  5. add image from step 3 to material from step 4
  6. make auto smooth active
7 bake normal map
Here are test files for 2.79 and 2.80. Both cubes have auto smooth at 30 degrees. If you press bake you can see that results are different. 2.80 bakes normal map as if it tried to transfer normals from smooth version of the cube onto the sharp one. Exact same thing happens with edge split modifier.
Sebastian Parborg (zeddb) triaged this task as Confirmed, Medium priority.
I think this might be related to T61912, but I'm unsure.
