gltf2 import: TypeError: '>=' not supported between instances of 'tuple' and 'int'
Operating system: Windows 10
Graphics card: NVIDIA GeForce RTX 2080 Ti FE (x2)
Broken: 2.80 337eb8c1de4c
Worked: N/A
Importing glTF 2.0 file results in an error in gltf2_blender_mesh.py on line 135:
I simply tried to import a glTF file that I exported from VRoidStudio.
I fixed it locally...
I noticed a nested 'for' loop around line 149 in gltf2_blender_mesh.py using the same variable 'i' as in the outer loop, and this 'i' appears to be clobbering the existing 'i'. Changing this inner loop to a different variable, like 'ind' (for index), resolved the error. (The mesh and armature doesn't load well, but it loads.)
I renamed the VRM file to GLB and zipped it here, so you can perform the same test:
Brian Jared (bjared) updated the task description. (Show Details)
Are sure about this? I haven't had time to test the glTF import, but the actual error from line 135 surely can't be fixed by editing code that happens after it. Also I don't see a nested loop in 149 where i would be shadowed. Can you submit a patch/diff? This is probably easier to discuss.
Julien DUROURE (julien) triaged this task as Needs Information from User priority.Apr 5 2019, 12:24 PM
Can you please try with a more recent build.
This should already been fixed few days ago.
Hi, Julien. I just downloaded the WIndows 64-bit build (d140e597a6a8), and it works.
I see on line 112 of gltf2_blender_mesh.py, the outer loop's iterator was changed from 'i' to 'sk' which is why that error no longer appears.
I should have checked for a newer build before posting. My apologies, and thank you for looking into this so quickly.
Brecht Van Lommel (brecht) closed this task as Resolved.Apr 5 2019, 6:11 PM
