changing scene and applying modifiers #63345
5 Participants
Reference: blender/blender#63345
Operating system: Linux-4.13.10-041310-generic-x86_64-with-debian-stretch-sid 64 Bits
Graphics card: GeForce GTX 1050/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 390.67
Broken: version: 2.80,
a813e259d6
Worked:
b936d7b16c
Creating a new scene or appending one, then making it the current scene, then copying an object from the previous scene and using
object.to_mesh()
to apply the modifiers will fail to apply the modifiers. See the attached blend and the script for clarification.This used to work just fine in
b936d7b16c
, but doesn't any longer, since at leasta813e259d6
.I'm assuming it has to do with
46eb5a0b8a
or similar changes at the time.Exact steps for others to reproduce the error
I'm not even sure if this is a bug, or now expected behavior. In any case, I'd expect it to behave the same, whenever I do the scene change. Hence the report. If this is indeed expected behavior, I'd really appreciate an explanation, thanks!
apply_mods.blend
Added subscriber: @MACHIN3
#63399 was marked as duplicate of this issue
Added subscribers: @kursadk, @Sergey, @rjg
This comment was removed by @rjg
@MACHIN3, the issue is fixed by
df26f28835
, but this opens slightly different topic: theto_mesh
function requires dependency graph to be evaluated. This means, constructing new scene and trying to doto_mesh
from it will not give correct result.This is one of the topics i wanted to raise with other developers during the homestretch, so keeping the report open for until some design decision is made here.
@Sergey Thanks, much appreciated!
I think
b7a09114f6
reintroduced the problem, after it was fixed bydf26f28835
as you mentioned.@MACHIN3, ah, well. It worked by accident, by doing logic based on uninitialized variable. The issue is that the evaluated mesh is requested for a non-evaluated dependency graph. For some reason quick adjustments to the script didn't solve this. Looking deeper into it..
Added subscriber: @brecht
I believe this may be solved by the latest API changes, in that if you ensure the depsgraph for the new scene is updated then
to_mesh
on the evaluated object should give the proper result?Changed status from 'Open' to: 'Resolved'
Yep, thank you!
