Remove doubles not working corectly
Operating system: Wind 10 64bit
Graphics card: GTX 1070 SLI (notebook)
Broken: (example: 2.80 Beta Windows 64 bit
April 07, 01:42:06 - d2d84132ddf9,
I have imported DXF file, converted into mesh from curve. I wanted to clean objecs from vertex (to many) and crete conections between vertex in the mesh (to create loop). But i started to have a problem with extrude ( object was for example without one side face or more) So i tried to remove doubles. But i couldnt. On the preent screen you can see 2 vert in one point. After using delete doubles, you can still see there 2 wertex (i did this when the wirefeame was turned on and "show whole transparent)
funny thing, when i switched mesh option -> face select, the edge was looking like face (preent screen ) or face like edge. I have turned ctrl + g up and you can se that this face act like edge
second issue - when i used option delete doubles on vertex, blender deleted at first time 3 vertex, next 3, next 2, next 1 almost 5 times i toke to rid of those vertex .
3 issue (look at the screen whats happening when i used extrude.
Philipp Oeser (lichtwerk) triaged this task as Needs Information from User priority.
The archive (.rar) seems to be broken for me, could you reupload here as a zip?
Since last asking for information it has been 7 or more days, due to the policy of our bug tracker we will have to archive the report until the requested information is given.
