Normal map node doesn't works with curve objects (or any object without UVs) in EEVEE #63424
8 Participants
Reference: blender/blender#63424
Operating system: Linux-4.15.0-46-generic-x86_64-with-debian-buster-sid 64 Bits
Graphics card: GeForce GTX 1070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 390.116
Broken: version: 2.80 (sub 54), branch: blender2.7, commit date: 2019-04-07 15:02, hash:
75f551faca
Worked: cycles
Open file, open lookdev (or rendered, but add some HDRI to clear view effects)
normal map test 3.blend
You will see something like this. Left object is curve, right - default mesh cube:
Normal map affects on cube, but not on curve object. Normal map also plugged into color, to preview, that texture coordinate works well.
Added subscriber: @crantisz
Added subscriber: @ZedDB
I'm getting a lot of depsgraph asserts when going into the material tab. (But I'm unsure if they are related or not)
The issue here is not with curve objects, you can convert the curve object to mesh and the issue is still present.
The cause seem to be the normal map node as you pointed out. If i just connect the normal map texture to the normal input on the shader, I get modified normals.
But if I pass it through the normal map node, this doesn't happen.
Yes, and only adding empty UV map solves the problem. So it's looks like Normal map node doesn't work without UV-map...
Normal map node doesn't works with curve objects in EEVEEto Normal map node doesn't works with curve objects (or any object without UVs) in EEVEEAdded subscriber: @Foaly
Just a little note:
The problem here seems to be that curves don't have tangents. You can check this via the tangent node set to UV Map mode.
However, when curves are evaluated as a mesh, they get tangents (e. g. by adding a modifier).
So a possible workaround to get tangents for now is to just add a modifier that does nothing.
Added subscriber: @MikeFutcher
"So a possible workaround to get tangents for now is to just add a modifier that does nothing."
Sounds like a good solution - except I can't get this to work either. Do you have a mod that works with this?
@MikeFutcher I think I used an Array Modifer with count set to 1.
Added subscriber: @fclem
Added subscriber: @iss
oops, haven't noticed this has been triaged
This issue was referenced by
15350c70be
