Grease Pencil Fills are see-thru with on 3d objects
Operating system: Windows 7 64-Bit
Graphics card: Nvidia GTX 1060 3GB
Broken: 2.8
The grease pencil fills are see-thru; I can see the fill strokes that are drawn on the other side of the 3d object I drew them on.
I drew some grease pencil strokes on the surface of an 3d object
The layer depth order is set to "2D Layers"
I set the depth order to "3D Location"
The grease strokes sink into the 3d object
I set it back to 2D Layers
If you set to 2D layer, you will have the transparency issue (this a know problem). You must set to 3D Space.
To fix the "sink", just move slightly the GP object on the Y axis and solved.
EDIT: Use full solid colors. Alpha colors are not supported with meshes yet.
Antonio Vazquez (antoniov) lowered the priority of this task from Needs Triage by Developer to Needs Information from User.Apr 11 2019, 1:04 PM
Since last asking for information it has been 7 or more days, due to the policy of our bug tracker we will have to archive the report until the requested information is given.
