animated custom property does not change value when animation is rendered #63548
7 Participants
Reference: blender/blender#63548
Operating system: Windows 10 Home 64 Bit
Graphics card: NVidia Geforce GTX 1050
Broken:
2.80-009dbc2bc9fb-win64
When running the attached .blend file the custom property 'CustomProperty' of object 'Cube'
is always zero during render, but it is animated to go from 0.0 to 1.0 with keyframes.
With a pre frame change handler I print out the value (and change the cube material according to it),
and during render the value is always the last one dependeing on the frame currently selected in the scene.
Load the attached .blend file
RenderNotAnimatedBug.blend
Make sure the script is executed at least once
open the system console
play animation to make sure the custom property of Cube is updated (Cube also changes color according to property).
Press Ctrl+F12 to render animation
Verify in the system console that custom property is not updated and sticks to last selected frame value.
Added subscriber: @hansfbaier
#63549 was marked as duplicate of this issue
Added subscribers: @angavrilov, @ZedDB
@angavrilov do you want to take a look at the cause of this?
By all looks this seems to be a depsgraph / COW / Python API issue, not related to animation as such.
Added subscriber: @TakeshiFunahashi
Added subscriber: @Sergey
@Sergey do you want to take a look at this?
What happens here is that you're accessing property from an original datablock, but it's actual value is only known at the evaluated version.
It is now possible to access evaluated datablock, read property value from it and modify original datablock based on that.
Attached modified version of the script to illustrate the difference.
RenderNotAnimatedBug_FIXED.blend
See https://wiki.blender.org/wiki/Reference/Release_Notes/2.81/Python_API#Handlers for more details.
Added subscriber: @ichlubna
@Sergey Can be similar principle used for custom compositor node properties? The problem sounds quite similar.
