EVEE: No shadows at orthographic camera
Closed, InvalidPublic
Operating system: Windows 10
Graphics card: GTX 760
blender-2.80.0-git.009dbc2bc9fb-windows64
I dunno know if it's a bug.... But there are no shadows in EVEE at Orthographic camera. But In 3d Viewport I see shadows.
File:
Orthographic Camera:
3D Viewport with Perspective:
  • Open the blend file
  • Press "0" to get into my Ortho Camera
Sebastian Parborg (zeddb) triaged this task as Confirmed, Medium priority.Apr 17 2019, 2:51 PM
I do get shadows on my end, but the shadows do not match and seem cut off in ortho mode.
I have to increase the Cascade Size to get the shadows to match better. However even with the highest setting, the shadow visibly doesn't match.
@Clément Foucault (fclem) as mention in https://docs.blender.org/manual/en/dev/render/eevee/shadows.html , the shadow map for sun lamps depends on the view, so I guess differences is expected. However is this much of a difference normal?
I set Solid Mode and switched shadows on. They work in othographic camera. But Evee still has no shadows. ((
As stated in the tooltip of Cascaded Shadow Map > Max Distance : the maximum distance covered by the shadow cascades is only used in perspective. In orthographic view the whole frustum is used for cascade bounds.
I think the latest bit is missing from the manual. But this is not a bug. Just how the implementation behaves.
However, if reducing the view Clip End value does not help, this is a legit bug.
Ok. Thank you for your time.
Yepp, adjusting clip end works on my end!
Could you please give a file where it works. Or show a screenshot which values i should set.
