Particle edit effects not visible hair every time.
Operating system: windows 10 64bit
Graphics card: nvidea gtx 1060 6g
Broken: (example: 2.80, edc1b0167518, master, 2019-04-16, as found on the splash screen)
If I comb, cut, puff, or do whatever on particle Edit mode, cursor select everything on it. Even if 'show whole scene transparent' not turned on, cursor effects everything including not visible hair
select the model, go to particle edit mode, and do whatever feature. it effects every hair even its not visible
Sebastian Parborg (zeddb) triaged this task as Needs Information from User priority.Apr 17 2019, 3:34 PM
I can not reproduce, it seems like the mesh is blocking the hair tools as expected:
You mean that the strokes go through the mesh for you?
Yeah for some reason the strokes go through the mesh. I can't get the reason.
Are you using the latest nvidia drivers?
I just installed the latest nvidia driver, but still not working as the vid
Sebastian Parborg (zeddb) raised the priority of this task from Needs Information from User to Confirmed, Medium.Apr 17 2019, 6:11 PM
I can confirm this now. I was on an older build before by mistake.
@Germano Cavalcante (mano-wii) I've bisected and it seems like your commit rB681661dbed121c7b81e9129c57df5eadb03c1009 broke this.
Brecht Van Lommel (brecht) raised the priority of this task from Confirmed, Medium to Confirmed, High.Apr 18 2019, 10:58 AM
sorry but how I can use this fix
@Ahmed Badawy (AhmedBadawy) Wait for the new version to be updated with the fix here.
Tomorrow, or the day after should be up.
All right, thank you so much.
