Broken links in the documentation project homepage #63702
Eevee & Viewport
Rendering & Cycles
Needs Information from Developers
Reference: blender/blender-manual#63702
I was reading the documentation homepage to learn how to contribute and noticed a couple of broken links in the "How to build & edit the docs locally" section.
Both links, listed below, are broken in the same way. They reference the path
style_guides
whereas it should beguides
.Markup Style Guide
Currently points to: https://docs.blender.org/manual/en/dev/about/contribute/style_guides/markup_guide.html
Should point to: https://docs.blender.org/manual/en/dev/about/contribute/guides/markup_guide.html
Writing Style Guide
Currently points to: https://docs.blender.org/manual/en/dev/about/contribute/style_guides/writing_guide.html
Should point to: https://docs.blender.org/manual/en/dev/about/contribute/guides/writing_guide.html
Apologies if this issue shouldn't be reported here, given that the problem isn't with the Blender manual.
Added subscriber: @panic
Added subscribers: @brecht, @ZedDB
@brecht who is in change of this?
