This page is in the process of being fully replaced by Modeling.
Order of importance:
- Very Important - These we should handle before the next release.
- Somewhat Important - These issues would be nice to do as soon as possible
- Less Important - Extra polish, nice to have
- ? Incomplete - Tasks needing more details before implementing.
- (straightforward) - Task which is straightforward to implement, which don't rely on larger API changes or refactoring.
Long Term Projects
Development may span multiple release cycles.
- T73360: Fast highpoly mesh editing
- T67997: Retopology in Blender
- T73993: Snapping & precision modeling improvements
- T67744: Boolean Redesign
- T68887: Text object editing rich text and UI/UX
- T57239: Remove DerivedMesh
- T68836: Transform Refactoring
- T56160: Stabilize boolean's epsilon use, write tests
- T50597: Gizmo position is wrong for meshes with modifiers
Medium Term Projects
Development should be possible in a single release cycle.
- T68891: Subdivision surface settings part of the Mesh
- D5344: Blueprint tool
- D5516: GSoC 2019: Bevel Custom Profiles
- T73139: Weld Modifier Improvements
- T68498: Outliner: Mode Toggling
- T68337: Improve Interior Face Selection Method #2
- T69979: Make "offset edge loop" slide evenly
- D3672: Multi-Objects: MESH_OT_select_similar_region
Object Editing
- T73400: "Affect Only: Parents" ignored for "Snap to ..." and "Clear Transform" (straightforward)
- T72621: Transform object origin support for grease-pencil (straightforward)
- T72622: Transform object origin support for mesh, lattice & curve shape-keys (straightforward)
- T74176: Transform object origin support for collection instances
- T73908: Support modal axis & user/local space switching for the shear tool
3D Text Objects
- T71529: Text object automatic bold/italic creation when font's aren't present
- T71484: Text object font picker UI
- T71999: Text object kerning, expose in menu (straightforward)
