Cycles and EEVEE on Mirror Blender 2.80
Closed, InvalidPublic
MacOS 10.14.4 Mojave
5K
27"
2017
Blender 2.80 BETA recent last download April 16, 2019
I am going show you 2 different pictures.
Cycles it work on mirror.
EEVEE not work on mirror.
Brecht Van Lommel (brecht) triaged this task as Needs Information from User priority.Apr 21 2019, 11:57 AM
For Eevee, you need to manually enable effects like screen space reflection, and add light probes for more accurate reflections.
Please try those, and if it doesn't work we need a .blend file to reproduce the issue.
Ok sure.
1 file
2 pictures
Push the F12 key for Mac only and Render Image I don't understand how work on EEVEE Render image.
My wrong date I mean April 16, 2019. Not 26. @Brecht Van Lommel (brecht)
Brecht Van Lommel (brecht) raised the priority of this task from Needs Information from User to Needs Triage by Developer.Thu, Apr 25, 12:32 PM
Please understand that this website is not a user support system, but a bug tracker where we handle reports in the priority that we define. It's not necessary to remind developers of open reports.
Sebastian Parborg (zeddb) triaged this task as Confirmed, Medium priority.Thu, Apr 25, 5:14 PM
I can confirm that it seems like the reflection plane works in the viewport but not in the final render (Linux, AMD).
Allright thank you for let me know. I am use Macintosh Mojave 10.14.4
The reflection plane is showing the data it captures by default. This is in order to make placement more easy. But they are not actual geometry and will not appear in final render. You need actual geometry close and aligned with the planar reflection probe. Then you need to uncheck show data on the probe object viewport display.
This is not a bug.
@Clément Foucault (fclem)
I don't understand text only. How can fix. can you send me screenshot and I will check there Blender 2.80 recent download May 8, 2019
