Object scale affects viewport shading in workbench
Operating system: Windows 10
Graphics card: NVidia GeForce GTX 1070/PCIe/SSE2, driver 4.5.0 NVIDIA 419.67'
Broken: rB7d6a9b551759, (blender2.8 HEAD)
Worked: ?
Applying object scale change the look of the object in workbench.
In the file above apply scale (Ctrl + A > Scale). You should see the look in the viewport changing drastically.
Note that even if I disable Auto Smooth from the Mesh panel the issue is still there.
Same happens for EEVEE and Cycles. So I would start investigating the apply scale operator...
Sebastian Parborg (zeddb) triaged this task as Confirmed, Medium priority.Apr 25 2019, 3:15 PM
I see the same effect as in blender 2.79. is this really a bug?
Brecht Van Lommel (brecht) closed this task as Archived.
This is not a bug. Vertex normal weighting depends on object space geometry, and if that gets non-uniform scale applied the result will be different.
