Image sequence node in material does not update via keyframes correctly in Eevee rendered animation.
Closed, DuplicatePublic
Graphics card: GeForce GTX 1080/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 419.67
Broken: version: 2.80 (sub 55), branch: blender2.7, commit date: 2019-04-08 21:54, hash: rB2a79e3463130
To give context I am keyframing the "offset" of an image sequence node within a material. It is set to show 1 Frames with Start Frame set to 1.
I will animate the offset with a range from -1 to 4, shuffling between these frame to animate a texture in the timeline. Doing a viewport render of the scene will result in correct frames being presented at the right times, but, if doing a proper animation Render it will skip crucial keyframes or appear to have a different offset entirely and hold the image sequence on the wrong frame(s). The keyframes were auto-created with default handles and interpolation.
Casey (BagelCo) added projects: Animation, Nodes.
Casey (BagelCo) renamed this task from Image sequence in material does not update via keyframes correctly in Eevee rendered animation. to Image sequence node in material does not update via keyframes correctly in Eevee rendered animation..
Stephen Swaney (stiv) triaged this task as Needs Information from User priority.Apr 23 2019, 12:56 AM
It would be nice to have a .blend for this.
Is this Blender 2.80 or 2.79?
Blend file: http://pasteall.org/blend/index.php?id=51609 I've gotten the same results on 2 computers, I imported the scene to a fresh project and still have this issue.
This is on 2.80. All the version information was added automatically by blender via the "Report a bug" button.
Stephen Swaney (stiv) raised the priority of this task from Needs Information from User to Needs Triage by Developer.Apr 23 2019, 4:31 AM
Thanks. My confusion. Apparently, buildinfo is misbehaving a bit.
Sebastian Parborg (zeddb) triaged this task as Needs Information from User priority.Thu, Apr 25, 5:24 PM
The image sequence is not packed. Could you provide it?
Casey (BagelCo) added a comment.EditedThu, Apr 25, 5:35 PM
Sorry, I ticked the "automatically pack into .blend" button and figured it'd pack the data. I guess the "pack all into .blend" is what I'm looking for? I'll get it soon
This comment was removed by Casey (BagelCo).
https://www.dropbox.com/sh/8cerh70mqv6b981/AADouiPZkg1I-kOBxyBhXE6qa?dl=0 here's the image sequence.
Sebastian Parborg (zeddb) raised the priority of this task from Needs Information from User to Confirmed, Medium.Fri, Apr 26, 11:28 AM
You can attach files here. No need to upload it to dropbox.
Anyways, I can confirm that it does indeed seem like the final render is skipping frames or sometimes even displaying the wrong frames:
Cycles test render (incorrect result):
Viewport render (correct result):
@Brecht Van Lommel (brecht) is this a known issue?
