Instanced objects get their viewport display color ignored (by design) #63830
6 Participants
Reference: blender/blender#63830
Broken:
022ad41670
Worked: 022ad416702d~
Instanced objects get their viewport display color ignored.
This is by design, as you can see in 022ad41670:
viewport-display.blend
My issues with the design
The original commit seems like a workaround for the fact that the override system is not implemented yet.
I find this too arbitrary and I would favour the flexibility of having a per-object granular viewport display object color instead (i.e., revert the mentioned commit).
Added subscriber: @dfelinto
#73802 was marked as duplicate of this issue
Added subscribers: @WilliamReynish, @mont29, @ideasman42, @pablovazquez
@ideasman42 any strong instance on this?
@WilliamReynish & @pablovazquez thoughts?
(friendly poke to @mont29 to be sure this case is covered by the upcoming override system).
Added subscriber: @brecht
Viewport display settings in general are inherited from the instancer, and it's really important to be able to do this for big scenes where you want to e.g. show just bounding boxes. It's arguable if object color is such a viewport display setting or not, I don't have a strong opinion on that.
To my knowledge, neither the library nor view layer override system design can efficiently handle this case. They rely on making actual copies of datablocks, but for instancing it's important that this does not happen and that instances use only little memory.
It is possible to have a lighter override system that is implemented in Eevee, Cycles and other renderers, where the extra memory cost would be just the changed properties. And as far as I know that's what the draw manager is sort of doing for this case. But the current override system design does not account for it, so it won't automatically solve this.
While this case is border-line, I think in general it makes sense to use the instencer unless there is a strong reason not to.
Axis & Name: don't inherit since you typically only want to see the axis of the object your instancing, applying recursively would show a lot of noise.
In-Front: Should be controlled by the instancer because you might want to show a prop ontop over the backdrop without having to go in an edit multiple collections to adjust something you most likely want to change temporarily at the object level.
Color could be either, however we already have display colors for materials, and currently color manipulation is performed on the scene selection, eg:
The result of both of these actions is less useful if the colors you're adjusting aren't used.
Object colors are useful as a way to set your own local color identifiers, if the instanced objects colors are used there isn't an obvious way to select objects and set their color, it could end up being quite complicated especially with nested groups, or impossible - for shared objects.
Note that we should check on each of these options, currently 'in front' isn't using the instancers options.
Added subscriber: @crantisz
This comment was removed by @crantisz
Added subscriber: @JulienKaspar
I originally brought this issue to Dalai because I am using vertex colors also for pre-viz in workbench just like material colors.
Interestingly when no vertex colors are detected, the color will default back to object colors.
Since I needed to define some objects as trasnparent I had to use object colors as a result since vertex colors don't have an alpha value.
This is where the issue of instancing came in since all instances replaced the object colors I had set up.
It's a corner case and I definitely get the justifications to keep the current design.
I instead propose that we could create a UI and implementation design to let the user choose if they want to use vertex colors with material or object colors as a fallback.
This of course would also need to be discussed with the planned change of the vertex colors in sculpt mode and attribute colors.
