Unicode paths results in "No such file or directory" #63853
5 Participants
Reference: blender/blender#63853
Hello,
Operating system: Windows 10
Graphics card: Quadro M1200 + Intel HD 530 (but this is not relevant)
Blender version: 2.79b (Date: 2018-03-22, Hash:
f4dc9f9d68
)Error:
I try to open a blender file using the command line (for scripting), and the current working directory (
D:\Dev\Thèse\article
) has accents in it, which are mangled by blender. Additionally, I give it a python script for which a similar error occur. Here is what I tried on cmd:So:
Thèse
got mangled toThÞse
, but the image is actually not saved...Seems like just a problem about unicode paths (I don't know the Blender internals though).
Added subscriber: @T.L
I could not reproduce the issue in Blender 2.79b and 2.80.
Does the same issue happen when only the .blend file has accents in its name? If yes, can you upload such a .blend file please (just to be sure, that we have the same symbol in the file name).
I just tried on another computer with Windows 10, with a file named
scène.blend
(it is just the default scene, with a simple cube). I did not use python in this second test.I put this blend file in two folder, so that on path is ascii-only, the other includes an accent (expérience):
First file
Work as intended:
Second file
Does not load:
So it seems to be only affected by accents in the folder, not in the filename.
scène.blend Here is the file with accent (but, as said, only the folder part of the path seems relevant here)
Thanks. Unfortunately, I still can't reproduce it (on Ubuntu 18.04).
Can you check if the same problem exists in Blender 2.8?
Does the same problem happen when you use Powershell?
Oh, I see, maybe there is some mismatch between utf8 on Ubuntu and utf16 on Windows/NTFS ?
Exact same behavior with Powershell. However, double-clicking the file in the file explorer works as intended.
I need to install Blender 2.8 to test, I'll keep you informed.
Added subscriber: @LazyDodo
Can't repro on 2.8 on windows
I tried with Blender 2.8, the version that I downloaded today (5 13b71c89ad0, I separated the digits to avoid another unrelated ticket !):
D:\Dev\temp>
blender scène.blend
WORKSD:\Dev\temp>
blender expérience/scène.blend
WORKSD:\Dev\temp>
blender expérience\scène.blend
WORKSD:\Dev\temp\expérience>
blender scène.blend
FAILS (Error: Cannot read fileD:\Dev\temp\expÚrience\sc├¿ne.blend
: No such file or directory)It seems to fail only if the current working directory contains non-ascii characters.
Can confirm this on windows. @JacquesLucke can you try on linux?
Added subscriber: @rjg
It's quite possible that this isn't a bug in blender, but another case of the strange way Windows handles encoding / code pages. Depending on your locale, it may be that
è
is not included in your code page, which results in Windows replacing the character with?
when passing the argument to the program. If that is the case, then there is nothing blender can do, because it's not getting the right string. You can check if that's the case by temporarily activating the UTF-8 beta feature described here. If that works properly, it's Windows' fault.Seems to be a different cause.
I'm on a french Windows, and by default my code page is 850, which includes these characters.
This seems improbable though: the arguments and the current working directory should have the same encoding (Windows-wise), but for some reason Blender only understands the arguments correctly, not the working dir...
@T.L Yes you're right, that's why I wrote that it seems to be a different cause.
I cannot reproduce it here.
Marking as confirmed, because @LazyDodo reproduced it.
This issue was referenced by
941575b1f7
