Crash when using object texture coordinates.
Closed, DuplicatePublic
Operating system: Darwin-18.2.0-x86_64-i386-64bit 64 Bits
Graphics card: Intel(R) Iris(TM) Plus Graphics 640 Intel Inc. 4.1 INTEL-12.2.17
Broken: version: 2.80 (sub 58), branch: blender2.7, commit date: 2019-04-24 02:30, hash: rB1b839e85e142
object coordinates for texture causes blender to crash
  1. go to shading workflow.
  2. Add any texture node Ex. Gradient texture.
  3. Add texture coordinate node and use object coordinates.
  4. Set object to any object in scene.
  5. crash
Note: it doesn’t crash if draw mode is set to rendered and render engine is set to Cycles
in this .blend I've set up the steps. 1, 2 & 3 simply select an object from the dropdown list on the texture coordinates node.
P.S. I have tested this on a system with these specs, Operating system: Windows-10-10.0.17134 64 Bits
Graphics card: GeForce GTX 1060 3GB/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 419.17 , with no crash, but it still will not update in the viewport unless you use Cycles.
Thanks!
