Right arrow to show properties region, won't work if you hide the header last.
In 3dview if the properties region is already hidden, and you hide the header afterwards. The tab to drag the properties region edge will not work.
If you restore header, and the tab icon move down again, will work.
Problem exist in 6d09fa357731 and rB1b839e85e142
@Campbell Barton (campbellbarton) I'm almost certain that has to do with the UI: ignore events in empty region overlap areas patches. Although I didn't check previous commit.
William Reynish (billreynish) lowered the priority of this task from 90 to 50.
Confirmed here. In fact I can't make the sidebar opening handle work no matter what. It seems to be consistently broken here.
Checked again. Need UI scale >1 (have 1.25).
Seems to be similar to T63920.
Can you still reproduce it?
Campbell Barton (campbellbarton) changed the task status from Unknown Status to Resolved.EditedApr 30 2019, 1:41 AM
Resolved in master rB8821757d0dd038de15ccec6df595b3496d120167, closing.
