Freestyle doesn't show up on any renderer
Operating system: Linux-5.0.9-2-MANJARO-x86_64-with-arch-Manjaro-Linux 64 Bits
Graphics card: GeForce GTX 750 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 418.56
Broken: version: 2.80 (sub 59), branch: makepkg (modified), commit date: 2019-04-26 08:14, hash: rB7440f98f980b
Worked: 2019-04-23 worked fine
Freestyle outline doesn't show up on any renderer.
Based on the default startup:
Open Blender, go to Render tab, activate Freestyle option and F12.
Happens with Workbench, EEVEE or Cycles.
Sebastian Parborg (zeddb) triaged this task as Needs Information from User priority.
Works for me with the exact same commit hash.
Does it work if you load factory defaults?
Forget to say i did load factory defaults, because i thought old config was the problem.
If you are using the default settings and just using the default cube scene, then I don't know what the issue is really.
Are you building it yourself?
I did use blender-2.8-git from the AUR repo.
But it happens the same with the latest build from blender.org.
So maybe the distro is the problem...
I just tested last source code and works fine in Windows 10 64 bits.
Does it work with the 2.79 git build from https://builder.blender.org/download/ ?
Does it help if you remove or temporarily rename ~/.config/blender/2.80 ?
I did try that too, but i finally found the problem. There were files in .local/lib/python3.7/site-packages/, maybe from the fake bpy module installed via pip...
After removing them it works fine.
Antonio Vazquez (antoniov) claimed this task.
