Transform adjust (location) bug
Closed, DuplicatePublic
Operating system: win10x64
Graphics card: vega 56
Broken: (example: 2.80.58, 5a144c797a3b, master, 2019-04-23
When I move object wich parent have some rotation transform and then try to ajust operation it's difficult to achieve the desired result
example is on attached video:
RUben (KUbo_0) renamed this task from Transform (location) bug to Transform adjust (location) bug.Apr 27 2019, 1:17 PM
Please can you send us the blend file to reproduce the issue? i can't reproduce it.
started new file with --factory-startup
fresh video
Philipp Oeser (lichtwerk) lowered the priority of this task from Needs Triage by Developer to Confirmed, High.Apr 29 2019, 9:44 AM
Can confirm this.
Looks like you can only adjust the constrained axis [other axis have no effect]
Also orientation seems to be local always? [possibly mixed up enum use?]
@Campbell Barton (campbellbarton) : are you OK with High prio?
This is caused by transform not having updates depsgraph (D4455 resolves however an alternate fix is planned).
