Scale gizmo center circle sensitivity issue
In Blender, the scaling sensitivity is based on the distance to the pivot point.
However, this causes an issue: When using the Scale gizmo to scale on all the axes via the Scale gizmo by dragging inside the center circle, the sensitivity is way too high, because the circle is always on top of the pivot point.
We can fix this by making it so the sensitivity is always fixed and constant when dragging inside the center circle, regardless of the distance to the pivot point.
Related Objects
William Reynish (billreynish) changed Type from Bug to To Do.
William Reynish (billreynish) triaged this task as Confirmed, Medium priority.
fixed in a different way now.
