Normal Maps not working on EEVEE
Operating system: Windows 10
Graphics card: gtx 1060 6gb
Broken: 2.80, 546e20f5a2c0, master, 2019-04-30
Worked: b46245470f79, 2019-04-21
Normal maps aren't affecting lighting correctly for objects in the newest build of Blender. Most of the time it looks like no normal map is being used at all.
  • Open default "cube" file.
  • Connect a normal map to its default Principled BSDF. Any normal map, really, but I'll be including one in this report just in case.
  • Using Cycles, go to rendered mode and check how the cube looks.
  • Switch render engine to EEVEE. Go to rendered mode.
  • Notice normal map isn't being properly applied.
Revisions and Commits
Philipp Oeser (lichtwerk) lowered the priority of this task from 90 to 50.Apr 30 2019, 11:06 AM
Can confirm, checking...
actually, it seems just fine if you save and reload the .blend...
(it is just the first time setting this up in a new material where this "fails"...)
@Clément Foucault (fclem): does this ring a bell?
