Red Line on menu bar (Mac OS) #64024
8 Participants
Reference: blender/blender#64024
blender_redline_bug.mov
{F6995492}System Information
Operating system: Darwin-18.5.0-x86_64-i386-64bit 64 Bits
Graphics card: AMD Radeon Pro 560 OpenGL Engine ATI Technologies Inc. 4.1 ATI-2.8.38
Broken: version: 2.80 (sub 60), branch: master, commit date: 2019-04-29 15:21, hash:
fa5dd59f98
I have a bug when use hide menu bar on my mac, please check that.
Added subscriber: @stalker0701
#70607 was marked as duplicate of this issue
#68913 was marked as duplicate of this issue
#70411 was marked as duplicate of this issue
#68965 was marked as duplicate of this issue
#67752 was marked as duplicate of this issue
#66921 was marked as duplicate of this issue
#66500 was marked as duplicate of this issue
Added subscribers: @WilliamReynish, @ZedDB
@WilliamReynish can you reproduce this?
No, it seems to work normally here on MacOS Mojave 10.14.4. Could be related to a specific GPU or driver version?
Most likely, yes.
So... i have 4 different Mac's and have this problem on all. When i use full screen mode i see the red line, but if i turn off "Automatically hide and show the menu bar" it fix this bug and i can work without red line in full screen mode
If you want to reproduce this bug you need to close blender, hide your menu bar and after open blender go to full screen mode. If you uncheck "hide menu bar" it fix blender red line and then you can switch back to the first setting and blender work correctly
@stalker0701 I still cannot reproduce it here, even if I do it in the order you describe.
Added subscriber: @brecht
We've had this reported before in #53123 (Mac OS X - System Preferences > General > Automatically hide and show the menu bar). The conclusion there was that it happens in other apps too which makes it likely to be a bug in macOS itself that we can't fix in Blender.
Are you seeing similar issues in other apps when going fullscreen?
So.. I use many applications and have this bug only with blender. But i have small bug in modo when i work with full screen, modo duplicate bottom menu line...look at this
Hello, after the last update I see huge red square :)
red_blender_bug.mov
Added subscriber: @jenkm
@WilliamReynish
Turn on both the "Automatically hide and show the menu bar" and the "Automatically hide and show the Dock" and then run Blender.
Also, this bug only appears when you switch to fullscreen mode from a maximized window (like Blender runs by default),
but if you resize the window a bit, then everything works fine.
Added subscriber: @arcnor
Added subscribers: @BenRacicot, @EitanSomething
Added subscribers: @DanielHoughton, @mano-wii
Added subscriber: @42demons
Added subscriber: @KarenA
Added subscriber: @Shawnee
Added subscriber: @robbarrett
Added subscriber: @sebbas
Was able to reproduce this in
ea1174bde9
following @jenkm 's description. In fact, this bug even shows up in 2.79 (tried out both 2.79a and 2.79b).It's likely that the OSX version plays a big role. I tested it on Mojave 10.14.6.
Removed subscriber: @KarenA
This issue was referenced by
5780142679
A fix for this issue has been committed thanks to @jenkm.
It's unclear if this fixes all cases. If there is a case not fixed in the next build, please let us know and provide exact steps to reproduce the problem.
bf361fc9a0
