Two Subsurface Scattering Node Mix Result Invalid #64110
Reference: blender/blender#64110
Operating system: Windows 7 SP1 64-bit
Graphics card: Geforce GTX 670
Broken: 2.80 Beta 2019-04-30 22:49
When mix two Subsurface Scattering node on Eevee, then result is broken and overexposed. Example: Mix two SSS node and set "Factor = 0", then result invalid, set "Factor = 1", result invalid, set "Factor = 0.5", result invalid, etc. etc.
Added subscriber: @spiderh
#64158 was marked as duplicate of this issue
Added subscriber: @StephenSwaney
Got a .blend showing the problem?
This is example file.
SSS Mix Problem.blend
Added subscriber: @ZedDB
This is a known limitation: https://docs.blender.org/manual/en/dev/render/eevee/limitations.html#screen-space-refraction
I'm not use "Screen Space Refraction", only use "Subsurface Scattering" and use only one object.
Right, I linked wrong. https://docs.blender.org/manual/en/dev/render/eevee/limitations.html#volumetrics
Only single scattering is supported.
This comment was removed by @spiderh
Added subscriber: @hyee_haw
@spiderh seems like I was too hasty. As pointed out in #64158, this is a regression. So we'll continue the discussion there.
