Lasso tool performs selection only if the object's pivot (origin) is within selection area (object mode) #64251
Closed
opened 2019-05-07 14:51:17 +02:00 by Ne Dudgi · 11 comments
Operating system: Windows 10
Graphics card: GTX 960
Broken: 2.8 bfef3bce1a
When in Object mode, Lasso tool performs selection only if the object's pivot (origin) is within selection area.
  • Load attached PivotOffset.blend
  • Go to Object mode.
  • Activate the lasso tool
  • Try to select the Cube object which has its origin at (-100,0,0) by completely surrounding it with the lasso tool
Expected behaviour: Cube object is selected
Resulting behaviour: Cube object is not selected
Precedent producing expected behaviour: Selecting the Cube object with the box select tool selects the Cube object, even if its origin is not within the selection area.
Desktop_2019_05_07_3984_0.avi
PivotOffset.blend
**System Information** Operating system: Windows 10 Graphics card: GTX 960 **Blender Version** Broken: 2.8 bfef3bce1a93 **Short description of error** When in Object mode, Lasso tool performs selection only if the object's pivot (origin) is within selection area. **Exact steps for others to reproduce the error** - Load attached PivotOffset.blend - Go to Object mode. - Activate the lasso tool - Try to select the Cube object which has its origin at (-100,0,0) by completely surrounding it with the lasso tool **Expected behaviour:** Cube object is selected **Resulting behaviour:** Cube object is not selected **Precedent producing expected behaviour:** Selecting the Cube object with the box select tool selects the Cube object, even if its origin is not within the selection area. [Desktop_2019_05_07_3984_0.avi](https://archive.blender.org/developer/F7012557/Desktop_2019_05_07_3984_0.avi) [PivotOffset.blend](https://archive.blender.org/developer/F7012554/PivotOffset.blend)
Author
Added subscriber: @blenderUser0803
Member
Added subscriber: @lichtwerk
Member
Confirmed behavior, checking [this was also the case in 2.79...]
Member
Added subscriber: @WilliamReynish
Member
Well, looks like this is by design, it is also documented in the manual https://docs.blender.org/manual/en/dev/editors/3dview/object/selecting/tools.html#lasso-select.
Same is true for circle select btw..
Guess we have to close this [unless @WilliamReynish thinks this is something to reconsider? (I am not sure what the reasoning for this difference -- box doing origins and geo, circle/lasso only doing origins...)]
Well, looks like this is by design, it is also documented in the manual https://docs.blender.org/manual/en/dev/editors/3dview/object/selecting/tools.html#lasso-select. Same is true for circle select btw.. Guess we have to close this [unless @WilliamReynish thinks this is something to reconsider? (I am not sure what the reasoning for this difference -- box doing origins and geo, circle/lasso only doing origins...)]
@lichtwerk Also not sure why tbh. Maybe because the use-case is if you have many overlapping/close objects? But even then it could be a tool option to do one or the other, for all the selection tools
Member
Added subscribers: @ideasman42, @brecht
Member
Maybe @ideasman42 or @brecht know?
Author
Did not check docs, my bad. Since this behavior is intentional, this is technically not a bug then.
Both kinds of functionality make sense (select by origin vs select by geometry), and both can be useful in certain situations. Although select by geo is more intuitive I think. I see the thing, I draw around it with the tool, done. But if they aren't consistent across similar tools, then it can be confusing for a new user or mistaken for a bug :)
One could argue that in most cases the origin is in the center of gravity of the object, so there's no apparent difference in the functionality of these tools. But that's not true lots of times. I come across meshes with stupidly placed pivots on a daily basis and sometimes I produce them as well, as I deal with my geometry.
If you can make this into a tool setting, great. If you want to go for only one kind, I recommend the geo version. Seems more intuitive to me.
Did not check docs, my bad. Since this behavior is intentional, this is technically not a bug then. Both kinds of functionality make sense (select by origin vs select by geometry), and both can be useful in certain situations. Although select by geo is more intuitive I think. I see the thing, I draw around it with the tool, done. But if they aren't consistent across similar tools, then it can be confusing for a new user or mistaken for a bug :) One could argue that in most cases the origin is in the center of gravity of the object, so there's no apparent difference in the functionality of these tools. But that's not true lots of times. I come across meshes with stupidly placed pivots on a daily basis and sometimes I produce them as well, as I deal with my geometry. If you can make this into a tool setting, great. If you want to go for only one kind, I recommend the geo version. Seems more intuitive to me.
Campbell Barton self-assigned this 2019-05-08 03:22:48 +02:00
Added as a TODO: #64282 (EEVEE & Viewport Module)
Reference: blender/blender#64251
