Option to lasso-select using geometry instead of object centers.
Confirmed, LowPublicTO DO
Currently lasso-select in object mode uses object centers,
This can have the option to select using the geometry (like box select does already).
See T64251
Campbell Barton (campbellbarton) lowered the priority of this task from 90 to Normal.May 8 2019, 3:19 AM
Campbell Barton (campbellbarton) triaged this task as Low priority.
Campbell Barton (campbellbarton) updated the task description. (Show Details)
Box selection doesnot have such an option.
Maybe it deserves it as well?
Select Circle in Object mode also use only object center.
Select lasso/circle are both hard to use at this point.
No, they complement each other, so you can select which way you need freeform selecting - circle for painting by centers or lasso for crossing, without changing preferences.
